Project: Ugly Cat
    • 7651
    Project: Ugly Cat
    Not quite sure what to call this at this time, I recently snatched this hull and hatch that he just happened to have around:
    I have one of these already but would like to do a different take on one.
    • 7651
    I am going to use some spare accumulated parts here on this one. Twin(of course) TP 4050 950kv oldies, Etti 120HV's. Speedmaster hardware on the back. As I said I have one of these hulls already running so I have my targets all set and will run 10s2p.
    I am going with motors on the tunnel and therefore the struts centrally located and rudder between. As opposed to BlownAway which takes a very wide stance
    This hull has no rails so a custom HRC mount shall be in order. This hull should be substantially lighter than BlownAway as well.
    • meangenesracing
      • 1168
      Shawn, call it Genos cat I'll take it when your done. LOL
        • 7651
        I’m aiming for good runtime and a basher boat here pal. Something to run at that lake nearby with the waterski course on it. I keep building pretty boats and then fear the marker buoys.
        But you never know what else I come up with.
        • Prodrvr
          • Jul 2015
          • 701
          Nice pile of parts!!
            • 4335
            Looks like a good start
            • TRUCKPULL
              • 2971
              Shawn
              I do hope that you are at least going to paint that hatch?
              A lower hatch may be in order.
              How big is that hull (10S-2P)?
              Larry
                • 7990
                The AC Boats R-42 is a great hull, especially for rough water. My 42” 10S version placed third among ~40 gas cats at the 2013 World's race in Houston. The hatch supplies a surprising amount of downforce, I would not change it out.
                  • 7651
                  Originally posted by TRUCKPULL View Post
                  Shawn
                  Larry
                  I run 6s4p in BlownAway Larry. Granted generally 42-4400mah packs. And you wouldn’t believe the pull it has toward me painting it. And y’know I prolly will.
                    • 7651
                    Jay, my friend took a shot at taking the hooking tendency out of the hull. He ground some of the leading edge of the runner in hopes that when the nose dropped in the corner that it wouldn’t carve inward. Just one side though for experiment sake
                      • 7990
                      That’s odd, mine didn't hook at all, neither in rough race water nor in tight turns. Haven't heard of this tendency from others either. All were single drives, perhaps twins exhibit hooking.
                        • 7651
                        Yeah BlownAway exhibits none of the hooking either but I recall someone(Howard?) in that thread mentioning it. I think it was there, I’ll have to re- read it
                          • 7651
                          I managed to get reinforcements done. I still need to clean them up but it is strong and still light.
                          • Prodrvr
                            • Jul 2015
                            • 701
                            Cool
                              • 7651
                              Originally posted by Prodrvr View Post
                              Cool
                              Surprising how much that stiffened it up out front. The hull itself is plenty strong but the upper deck was able to flex some. This I discovered on BlownAway from the only blow over I had. The clear coat got spiderwebbed from the experience. OUCH!! And since I am not sure where this hulls service duty will stop(SAW?), an ounce of prevention....
