Mono 33" Twin Setup, build advices
  • Alfa Spirit
    • 2183
    Hi,
    I' m building a 33" mono twin setup,
    Motors : 2960 , 2200kV , 1800 Watts maxi
    ESCs : 2 x Seaking 90A
    Batteries : 4S 3300mAh 60C - 120C Lipo per motor
    Any advice is welcome.
  • Crash
    • Oct 2015
    • 313
    sounds really cool. Good luck with your build...….
    • Alfa Spirit
      • 2183
      Thanks, do you have an idea about diameter and pitch for the propellers ?
        Geez, I guess you’ll have to go CNC to get CR props but I’d think 37mm could be a good size, maybe 35mm? I have a 40” twin mono running 442’s and it is running 50mph. TP 4030 1180kv on 8s 4200mah. I know it’s a different setup but it gives you an idea that you don’t need huge props to do well.
        • Alfa Spirit
          • 2183
          I was thinking about 38mm x 1,4 pitch for the props ...
          • RunningBeer
            • Aug 2014
            • 90
            I've built a couple of twin monos,there are pics on my page
            • Alfa Spirit
              • 2183
              Thank you for sharing, cool boats !
              What is the setup of the Delta Force Pirate ?
              • RunningBeer
                • Aug 2014
                • 90
                It's currently 2x SSS 4082 2200 KV on 4S with 150 amp raider ESC's and 44mm 1.4 props. Cheers .R Beer. p.s. A generous hatch size is important when selecting a hull for a twin!
                • Alfa Spirit
                  • 2183
                  @ RunningBeer
                  You build a "double" setup mono ! 4082 motors ... Is it a very fast boat ?
                  • RunningBeer
                    • Aug 2014
                    • 90
                    There's a bit of vid from an early run here https://www.youtube.com/watch?v=tobZ3H2icco . It's quick enough for my driving. The best part is how tight it can carve left and right turns.
                    • Alfa Spirit
                      • 2183
                      I have 2 sets of motors :
                      - 2 x 2960 2200kV , 175 Gr per motor
                      - 2 x 3660 2400kV , 240 Gr per motor
                      3660 motors are too heavy imho, what do tou think ?
                      • RunningBeer
                        • Aug 2014
                        • 90
                        The twin pursuit on my page had twin 3660's 2200KV on 4s. It's a similar size to what you are building.It was a weapon but I didn't reinforce the hull and she broke after several large crashes. I'm no expert but I think the 29's will struggle to dissipate the heat on a boat that big.
                        • Alfa Spirit
                          • 2183
                          If I use 3660 2400 kV motors I' m afraid the boat will be heavy , + 130 Grammes.
                          • akula
                            • Dec 2009
                            • 30
                            Hello Alain !
                            How are you ??
                            Do you really intend to start such a project ??
                            Do you know that you will have to use a drill and make holes in your hull ??
                            You should do like the other boats you have, and leave it in peace on a beautiful shelf.
                            cheers
