Sharpen rudder and turn fins?
  • jester_s1
    • Jun 2014
    • 82
    I have to assume that sharper is better for these on my deep V, but how sharp do you guys usually go? I can imagine a true knife edge wouldn't hold up very well on the rudder, but are there performance concerns with going sharper than stock?
  • Prodrvr
    • Jul 2015
    • 701
    Sharp enough to cut? I'd say not that sharp. Better gains can be had with mirror polishing the rudder, turn fins, struts, etc...
    • Stillwet
      • Jul 2018
      • 241
      not enough to slice your finger but sharp enough to cut white bread.
      • jester_s1
        • Jun 2014
        • 82
        Alrighty then. Thanks guys.
        • 785boats
          Wet Track Racing
          • 3423
          I've been wondering about that lately.
          A lot of us scuff the bottom of hulls & ride pads with some #400 paper in the search for that little extra speed. The theory being that shiny surfaces are a bit sticky, creating drag.
          Maybe scuffing the rudder, trim tabs, turn fins & struts could have the same effect in reducing drag on those items.
          Just wondering if anyone has tried it.
          I might do it to my mono for this weekends racing at our club.
          The results may be negligible, & impossible to prove, But hey, you never know.
          • Prodrvr
            • Jul 2015
            • 701
            On the hull, yeah. On the hardware...never heard of anyone doing it. I was always told by racers to mirror polish all the hardware. But I'm game for trying something new. Think 400 on the hardware like the hull?
            • grsboats
              • 1011
              In the early 90's I used to polish my hardware to mirror just for aesthetic looking.After a long discussion with some "hot dogs" I was convinced to not waste my time and since that I only scuff the wet area of my boats (mainly riggers) and let my hardware stock,obviusly my turnfins are very sharp and the front of my rudder blades.Props are carefully balanced,profiled and sharpened but NOT polished ....this from my experience! Gill
              GO FAST AND TURN RIGHT !
              www.grsboats.com.br
              • 785boats
                Wet Track Racing
                • 3423
                I've never bothered polishing hardware, but yes, I think that I'll try some #400 paper on it.
                Gill.
                I don't polish my props either. Just finish them off with some #600 paper. That all comes from an article I read years ago on a full size boat racer where he said that sometimes an old beaten & weathered prop performed better that a brand new bright shiny one of the same specs.
                • grsboats
                  • 1011
                  785 you are correct. I like to use some 3M rubber wheels (black,red,white) with different abrasive grits to finish mine but it is safe after that check the balancing again. Gill
                  www.grsboats.com.br
                  • Prodrvr
                    • Jul 2015
                    • 701
                    How about a hit with a red Scotchbrite pad?
                    • grsboats
                      • 1011
                      Never tried and take care to not scratch too much your hardware....3M dry sandpaper(Gold) first 320 and then 400 grit has also worked to me using a flat block of wood or metal.
                      www.grsboats.com.br
                      • Stillwet
                        • Jul 2018
                        • 241
                        when i use remodeling the Dragn' Fly 20, i used my Fire Stone ( electric knife sharpener) to get a starting edge on the turn fin. i cut deli thin sliced meat with it, but wet sanded and polished it not so darn sharp.
