Im planning to build a delta force mini sniper as a 2s or 3s boat. Its not for me but for someone else and I'm trying to keep the prices low while at least being able to get the boat into the 30 - 40mph speeds. Does anyone know of any setups that are capable of doing so for under $450?
Delta Force Mini Sniper Build
Tags: None
Also what do you guys think about using the Mini outboard motor system that is available on OSE for $74 along with the OSE raider 150A esc on 3s for this boat?
Hell ya! I love the Leopard 2860- 2550kv motor, a 120amp esc and 3 or 4s. Run up to a x435x3 blade detongued.
150 esc is too big. An old Hobbywing 120 v2 still available from Ali express or Banggood.
I think .130 cable is fine. It's what I've used and works fine. We are only pushing a 23" hull.
Do a search for DF23 and you will see some builds to help you out.
A bit over kill but you know what this hull maxed out can take size wise for components. Thanks Tony!
https://forums.offshoreelectrics.com...highlight=DF23
