1/10 Baby Bootlegger Build
  • AndyKunz
    • Sep 2008
    • 1444
    Thanks Doug. You make me feel SOOOO much better :sarcastic: :D It's good to build, especially with the carrot that's dangling!
    Full Size Image
    Full Size Image
    Before I could sand everything, I had to trim them to fit. I did this by using a 3" long blade as a drawknife. To do this properly, you need to watch what the grain is doing. I was only able to do a little over half the length of the hull from each direction. I turned the boat around to do the other end. It is important to trim the deck sheer also, because you will be planking there as part of the sides. Don't try planking the deck though - just the sides and bottom with it on the building board.
    Full Size Image
    After I trimmed them, I sanded. First I did the sides using a standard 12" block sander. The bottom (shown in the picture) was done with a sander I got several years ago for drywall. I don't know what it's called, but it has a permanent grit about 200 or so, and is made of a flexible foam. I used it because I could sand the concave hull bottom without damaging it as a hard block sander would do.
    Full Size Image
    After you're satisfied with that you get to start the time-consuming part - planking. This underplanking is easy - if things don't fit perfectly it's not a big deal. However, I urge you to learn as much about planking as you can - you're going to have a lot more difficult time when putting on the mahogany. You want it to be nice, remember!
    Note that the bow pieces are twisting and appear to be shingling. They aren't, really. The wood is being beveled and tapered in two directions, and the thickness makes it look like they aren't smooth. That's because they aren't. With the underplank you can do this, then sand smooth. Here is where you should take your time.
    By the way, when fitting the pieces are do the bow taper first (starting between bulkheads A and B). You don't need to be too precise on where the bow pieces end, either now or later. That's because the edge will get a metal cover over it.
    Full Size Image
    You'll want to make the transom look better when doing the final planking. Note also how the planking extends way past bulkhead H. This will be trimmed later also.
    I was very liberal with pins. I probably won't use quite so many when dong mahogany.
    For the next few days all I'll be doing is planking. The bottom is done with 1/2" wide planks. I'll keep you posted on what I use as I go along.
    Andy
    Spektrum Development Team
    • Ocean Racer
      • 511
      that is awesome and it not even finished
      Failure is the First step to SUCCESS
      • Jeff Wohlt
        • 2740
        Great work, Andy. Probably feels prety good again building a boat.
        Keep them coming as you progress. I will have you some hardware for your other soon.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • Doug Smock
          • 5359
          How's it coming Andy?
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • AndyKunz
            • Sep 2008
            • 1444
            #35
            I'm still working on the planking - this is the boring part, not much to show. Last night I pulled a zillion pins out of it.
            Most of my time I'm concentrating on an electronics project to help a friend in a bind right now. When that finishes and I finish a magazine article then it will be top priority again.
            Thanks for asking.
            Andy
            • robert1974
              • Jan 2009
              • 1
              #36
              BB
              Hallo Andy
              We (me and my son) are building the same boat and we are very glad we found your pictures and info/tips it saved us a lot of time trouble headache and tears :)
              Can you tell us something about the powersystem your putting in ?
              And we are anciously waiting for the next part.
              Greetings
              Robert and Gabriel from Holland
              • AndyKunz
                • Sep 2008
                • 1444
                #37
                It will likely have a Proboat BJ26 system in it. The ESC is Proboat part number PRB3309 and the motor is PRB3310.
                I will be posting more pictures in a couple weeks. I have had 3 high-priority ($$) projects to do, and the last should be done in about 2 weeks.
                The key when you get to planking is patience. Just do a little every day.
                Andy
                • woody5
                  • 8
                  #38
                  I've got the hull finished and am looking at motors and drive train options. Do you think the Englishman's plan for these elements is still a good option with todays more affordable BL motors?
                  If you go with the blackjack system are you going to use the out drive and prop also.
                  His rudder set up is very unusual.
                  • CornelP
                    • 793
                    #39
                    Any ideas on how to make the front cutwater? I tried soft brass, but the curve is too complex... the aft one was ok, will post some pics. I am now thinking to cheat and do it in ABS painted brass...
                    • woody5
                      • 8
                      #40
                      If you want to plate the ends in chrome the stainless self adhesive Duct tape is an easy answer. That tape is sold at most hardware stores here in Florida. You could paint the area of trim with metalic bronze or brass paint and then apply a coat of laminating resin to make it more durable. My hobby shop in town carries brass that is thin enough to make a scale cut water you would have to silver solder it and form the shape with a jewlers hammer. It would look real nice secured to your bow and stern with pin heads as nails. I am going to leave the cutwaters off to expose the laminated ends, I think they are to pretty to cover up!
                      Have you any ideas on how to make the G5?
                      • rcboatfan
                        • 253
                        #41
                        looks great!!!!!!!!!
                        SUPERVEE 27 37'' TWIN CAT
                        • CornelP
                          • 793
                          #42
                          For the G5: I will either order a custom decal or, because I have one , use my cutter/plotter (roland Stika SV12) on a sheet of thin self adhesive vinyl and use the negative as a template for gold paint... I am now working on an upgrade to a cheap toy cat for the holidays, but next week I will finish the Bootlegger... hopefully take her out on the water.
                          • CornelP
                            • 793
                            #43
                            Got the first run with it, just lovely. I f you push it, it will go like a dream...
                            • CornelP
                              • 793
                              #44
                              Second run, much better, but still need to fins a decent prop. It now runs on a 3 blade 32mm Graupner...
                              • JimClark
                                • 5913
                                #45
                                alright we need pictures of all the details especially the hardware.
                                Looks great
                                JIm
                                Billy Graham
