JAE33FE Build
  • M3Bluegsr
    • 105
    JAE33FE Build
    Here is my JAE33FE that I am close to completing. It will have TP 4082 2310KV, and Swordfish 220A esc, the rest is the complete combo from Zippkitts.
    The beginning, doesn't look like an RC Boat..
    Taped it together to check out the size.
    Lowered the battery height for more room, need to clean up a bit.
    Inner Frames, Sides and Bottom glued.
    Motor Arrived
  • M3Bluegsr
    • 105
    Size compared to the 12G4
    First time using a Swordfish ESC
    Second of 3 Coats of Finishing Resin
    Ready to Glue on top plate, hatch fitted and trimmed.
    Thumbscrews added to hold hatch, hate them falling off in transport!
    • M3Bluegsr
      • 105
      Ski on and glued to hull.
      Top plate being glued
      Sponson sheeting almost done
      Sanded and design taped for paint
      AutoAir Silver Sealer (Primer). Great paint to work with..
      • M3Bluegsr
        • 105
        Racing Green Candy over silver sealer and silver metallic base coat.
        Nice and even application for candy paints, Harbor Freight gun works nice!
        Tape removed and areas that will be black exposed.
        3 Coats of Transparent Black
        Ready for 2k Clear Coat
        • M3Bluegsr
          • 105
          2 coats of clear, you can see the candy coming out of the hatch. Need to wet sand and final clear coat.
          3rd clear coat going on in home-made paint booth
          Hardware going on, nice attention to detail with all the fittings from Zipp.
          Motor in, the pile of parts in back waiting to go in. This is current status, should be done end of week.
          • emspjay
            • Sep 2017
            • 411
            Looks awesome!! I really want to build one of these for my next boat.
            • M3Bluegsr
              • 105
              Thank you, they are really nice to build. Received the batteries today, need enough power for the TP motor, so I went with Gens Ace - 5800mah - 100c packs.
              • Doug Smock
                • 5264
                Nice work!!
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • M3Bluegsr
                  • 105
                  Originally posted by Doug Smock View Post
                  Nice work!!
                  Thank you!
                  • rol243
                    • Apr 2017
                    • 1038
                    Let us know how she runs with the T.P. 2320.
                    • M3Bluegsr
                      • 105
                      Will do, had a small typo its the 2310kv.
                      Made some progress, hope to maiden tonight. The only thing I would like included in the kit that is missing, is a stand. Would be nice to have a stand that is laser cut with Zipp logo. Not that they are hard to make, would be a nice option.
                      All Electronics in
                      Just have to sharpen fin, and attach sponsons
                      Turn-Fin sharpened and attached.
                      Might need to paint brass thumbscrews black, pretty much ready for maiden. What would you guys suggest for props to test? I put on an X442 to start and get setup right, then might try the provided 1450, or ABC H7.
                      • M3Bluegsr
                        • 105
                        Here's an action shot of the blue Jae..
                        • M3Bluegsr
                          • 105
                          Ready for maiden this afternoon:
                          • rol243
                            • Apr 2017
                            • 1038
                            good props; ABC H6 / H7 / zippkits 1450 mod.
                            • jim82
                              • Jan 2013
                              • 1358
                              Abc 1914 or 1915-17-45
