Mono Build
  • J.Cullen
    • 26
    Mono Build
    Im in the process of building a fe mono (my first build). My knowledge in this area's limited, lucky Ive got the help from a friend
    Ill post a few pics of the hull although I wont make a start until probably early-mid December. Its a fiber glass hull with a carbon bottom (on top of glass layer).
    Planned Setup:
    Motor: ProBoat Brushless A3630-1500 Motor (BlackJack)
    Speed Controller: X-Power Brushless 100a Esc
    Hardware: Octura Offset Rudder System
    Transmitter: Spektrum DX3.0
    and the other bits and pieces (motor mount, batteries (obviously), turn fins)
    Not the best quality setup (beat you to it "Spot me 2" hahaha ) but its defiantly a good start.
    Any Suggestions/comments?
    Here come some pics...............
    Drivin' down the highway...Fuuuuuuuuu
  • mtgoat
    • Apr 2008
    • 103
    Is that a BBY Oval Master hull?
    • calcagno45
      • Mar 2008
      • 1050
      Sounds good so far. Whats the dimensions on it? Are you going to be running LiPo or NiMh cells? how many?
      Also, trim tabs and turn fins definitely help stabilize the boat at higher speeds.
      • J.Cullen
        • 26
        Yep, its an Oval Master Hull. A guy at the local rc boat club made it for me.
        • Darin Jordan
          • 9446
          I hope that "guy" is Randy Naylor... Otherwise, someone is making unauthorized splashes of someone elses work...
          Darin E. Jordan - Renton, WA
          • calcagno45
            • Mar 2008
            • 1050
            or is he chinese? Seems like the Chinese like to copy some hulls...
            • RandyatBBY
              • 3943
              I would hope people would be smarter. It is not my lay up. Sorta looks like ABS lined with CF. Except for the rub rail on the front.
              Randy
              BBY Racing
              • J.Cullen
                • 26
                He's not Chinese and he isnt making them in "business quantity", its just a hobby. So basically its not a copy of someone elses work, although that shape is pretty much standard for an Oval Master.
                • J.Cullen
                  • 26
                  Well thats a relief, I was sure it was an original shape...
                  Its a GLASS hull lined with carbon (its been gel coated... i think)
                  Thanks for the interest
                  • Darin Jordan
                    • 9446
                    This is the last I'll comment on this thread... I'll let Randy take it from here if he feels like saying something... But if someone has splashed the OM26 and is making them for other people, then they've "copied" someone elses work...
                    I don't have a problem with this if it's for personal use and one gets permission from the originator, but if they are being distributed to others, and especially if they didn't have permission to do this, then it's a splash and IS taking someone elses hard work. They also took a sale away from the person who originally designed the boat and is still selling them.
                    Just my opinion. I won't comment further.
                    Good Luck with your build. It should be a nice boat when it's finished.
                    • mtgoat
                      • Apr 2008
                      • 103
                      If I'm not mistaken, BBY hulls do not come assembled. The hobbyist assembles the two hull "halves" along with any reinforcements there may be. I suspect Gumchild3000's "guy at the rc boat club" assembled the hull and added the carbon reinforcement.
                      • J.Cullen
                        • 26
                        JUST TO CLEAR THINGS UP....
                        (Relating to Darin Jordan's comment)
                        I had a bad choice of words, so Ill try again...
                        The Oval Master is BBY - I bought it second hand from "the boat club guy" and it was in "halves".
                        As I said before, my knowledge on the subject is limited, so I gave the hull back to him and he put fiberglass around the joins, assembled the boat for me and layed Carbon on the bottom of the hull.
                        What im trying to say is that the hull is BBY, and NO it was not a COPY of Randy's, it is a legitimate BBY hull.
                        Sorry for the confusion, I hope this makes it clearer.
                        • Darin Jordan
                          • 9446
                          Excellent... Build away, and post lots of pics! Most of all... HAVE FUN!!
                          • J.Cullen
                            • 26
                            Shall do, dont worry, there will be plenty of pics. Should be finished early Jan. If there's alot of interest ill keep posting pics and comments.
                            • mtgoat
                              • Apr 2008
                              • 103
                              Whew! Glad that's settled.
                              Not the best quality setup[...]
                              I don't know about that. IMHO, the Oval Master is an excellent hull, the Octura hardware works as well as anything else, and the Blackjack motor puts out plenty of power. What more could you want?
                              My buddy has the Oval Master 21 (smaller version), and it is incredibly fast and stable for such a small boat (40+ mph). I think you'll be very pleased with the way it runs.
