Venom Seagad 34" single brushless Cat
  • gsbuickman
    • Jul 2011
    • 1500
    Hiya Guys ,
    Lookie what showed up today Thanks to my mailman - A nice Venom Segad 34" kitty that's been setup for single brushless. Whoever did the conversion from Twin to single did a really nice job on this and I like the inline strut / rudder setup that's on it. The prop that's on it is an abc 445. I picked it up for $200 shipped and it came with the original esc's, 2700kv outrunners & twin drive hardware that was in it, so I got a lot of spare parts for my King of Shaves twin ...
    For now I'm thinking about using one of these 60A esc's and picking up something like an AQ 2030kv mill on 4s power for now. I'm thinking it should get right up and boogie fairly well with that set up in it.
  • Shooter
    Team Mojo
    • Jun 2009
    • 2752
    Sounds like a plan. Tried a true setup. Nice boat!
    • gsbuickman
      • Jul 2011
      • 1500
      • gsbuickman
        • Jul 2011
        • 1500
        Wow, just out of curiosity I went back and checked the conversation with the guy that I got this boat from and it looks like this boat is a deal that's been in the works for the last 10 months ...
        • Bp9145
          • Jan 2016
          • 1466
          I have this one as well as two of the C1, all twins and also the bigger 56" ARC. . . .i just love the paint scheme. I also had the blue KOS but sold it and now a regret as I would have the complete version of this cat. The funny thing is my SEAGAD still has not been in the water. For $200 you got a heck of a deal.
          • gsbuickman
            • Jul 2011
            • 1500
            Thanks, chilling with everything that came with it I thought I got a pretty good deal myself, especially with shipping included . Now I have a bunch of spare parts for my EKOS, now I just need a set of props to throw on it.
            Now I need to figure out what I want for a motor in the Segad. The stock 380 outrunners were 2700kv on 42mm props. I was thinking of an AQ 2030kv, or a 4 pole 3674 2350kv, but Leopard has a 3674 2650kv that could be tempting. It would be in the stock RPM range but with the 445 brass prop I think it might be a little much for one of these 60A esc's, even though it's a rebranded Turnigy Speaking & proven workhorses. The Seagad already had an esc go up in smoke in it as you can tell by looking at the bottom of the canopy and it still smells like the smoke of death. The last thing I want or need is to have another speed control fry in it ...
            • gsbuickman
              • Jul 2011
              • 1500
              Before I get froggy with this thing, I think it might be a good time to pick up some mat & epoxy or resin and do an inlay in this thing. If I can get some matting in something like canary yellow that would be cool ...
                Sand, sand and sand. IMO there is too much gooey stuff. You need to sand it down and expose fresh surface. I have done that as well.
                • hughb
                  • 152
                  Definitely needs a clean up inside if you want to do an inlay and have it bond to the hull. Before sanding, clean up the inside with acetone to remove any gummed up oil etc sitting on the surface of the fibreglass. This should leave the fibreglass still dark stained but otherwise dry (as in no oily residue). Then give a thorough sanding with heavy grit sandpaper till the stains disappear, this means there’ll be fresh fibreglass to glue the inlay in.
                  Then more acetone for further cleaning.
                  • gsbuickman
                    • Jul 2011
                    • 1500
                    Thanks Tim
                    I appreciate the heads-up on sanding the inside of the Hull down. It's not gooey at all per se. As a matter of fact it's really dry. I think that's just some varnish or epoxy type stuff from the factory which is probably what they used to stick down the motor mounts and stuff that were pulled out of it. If I go ahead with some kind of inlay it would primarily be for a Statics just to make it look better than anything and I was planning on sanding it down after pulling the servo and the motor mount out of it, but if I do some kind of inlay in it it will only be in the rear 14" of the Hull. I really don't see a need or a way to get an inlay any further forward than that in the sponsons and that's right where the flotation foam starts anyway. I can get a yellow 12"x12" piece of Tumblr / carbon fiber twill cloth for less than $20 so even with epoxy or resin it wouldn't be too much to get it done.
                    • gsbuickman
                      • Jul 2011
                      • 1500
                      Thanks Tim
                      I appreciate the heads-up on sanding the inside of the Hull down. It's not gooey at all per se. As a matter of fact it's really dry. I think that's just some varnish or epoxy type stuff from the factory which is probably what they used to stick down the motor mounts and stuff that were pulled out of it. If I go ahead with some kind of inlay it would primarily be for aesthetics just to make it look better than anything and I was planning on sanding it down after pulling the servo and the motor mount out of it, but if I do some kind of inlay in it it will only be in the rear 14" of the Hull. I really don't see a need or a way to get an inlay any further forward than that in the sponsons and that's right where the flotation foam starts anyway. I can get a yellow 12"x12" piece of Tumblr / carbon fiber twill cloth for less than $20 so even with epoxy or resin it wouldn't be too much to get it done.
                        Jim, sorry for my long winded post, I am sure you know what to do. I just couldn't help myself!
                        Good luck with the restoration, shoot some video when you get her going.
                        • gsbuickman
                          • Jul 2011
                          • 1500
                          Ha ha, it's all good Tim ...
                          • gsbuickman
                            • Jul 2011
                            • 1500
                            Hiya Guys ,
                            I know I've been a little sidetracked lately ( too many projects not enough time) but I haven't forgotten the Seagad. Yesterday I ordered a T180 speed control, 3674 2000kv motor and a flex collect for this beast. I'm also planning on ordering some of this yellow and black kelvlar / carbon fiber cloth for an inlay
                            https://m.ebay.com/itm/12-in-x-1-FT-...19.m1438.l2649
                            • gsbuickman
                              • Jul 2011
                              • 1500
                              Wahoo , the new power system for the Seagad showed up with my mailman yesterday. 3674 2000kv mill w/ cooling jacket & flex collect & a 180A Speaking v.3 esc. It has a cap bank installed and a pair of deans connectors in series. Bought these from the guy I bought the boat from, there new never run & I couldn't pass the deal up for $100 shipped ...
