I/8 Scale FE Hydro Motor /ESC Colloing Wate rlines
  • Tom G
    • Aug 2017
    • 57
    Getting ready to install cooling water lines in my 1/8 scale FE hydro hull motor is a NEU 1527/1.5/8 the ESC is a Alien power Sys. 300 Amp @ 8s
    Question is a single 3/16 Od .153 Id. line going to be sufficient for both or should I run 2 line's 1 for the ESC & 1 for the motor
  • 30nitro
    • Feb 2018
    • 330
    With that kind of power.....I would run two separate lines....
      I doubt that ESC will work too hard on that setup, I think as long as you run lines to ESC then motor one line should suffice. If you have a dual inlet rudder then you could go one line for each but don't Y or T the single line.
      • rayzerdesigns
        • Dec 2013
        • 1228
        3/16 should be fine especially if ur in a club that limits prop size to 55mm
