finally able to post some pics gutted the hull started painting i want to go brushless, would blackjack motor and esc be better than sv 27 motor and esc ? what hardware should i use rudder turn fin any suggestions would be great
hurricane rebuild
If you are wanting to go with a single motor, it will have to be a LOT bigger than that.
Try this for hardware:
http://www.offshoreelectrics.com/pro...prod=sol-hydro
What kind of speeds are you expecting?
The first thin gI would suggst doing it cutting out the ABS inner hull (if there if one) and coating the inside and transom with glass.
rescue status
the rebuild status of the hurricane is on hold, since i already have an sv27 and am in the process of building an mm hull, i will need a rescue vessal and this will be it. new paint and same running system should work fine, you can always push your baots to another level when you know if it flips or blows over you can go get it and bring it back
hopefull these two wont need many rescues
