37" TFL Genesis single motor SAW build
  • REDLINE1
    • 199
    #61
    I was lucky enough to be there today to see this beautiful boat screaming across the lake Great job Ryan!
      • 4340
      #62
      Thanks boys. I'm going to try and pull the log data off the ESC tonight and see what kind of RPM and Amp readings I got.
      • naveda_08
        • May 2021
        • 66
        #63
        wow impressive, you put a ton of work into that hull.
          • 4340
          #64
          Thanks. Yes, it was a lot of work, but I learned a lot during the process.
          • CraigGenesis
            • Jun 2021
            • 8
            #65
            What glue did u use ?
              • 4340
              #66
              This was one of my first builds. At the time I was using JB Weld for things like motor and servo mounts. I used 30min epoxy and chopped carbon fiber in the tips and for the deck stringers. Now I use mostly West Marine G-Flex epoxy thickened with silica powder
              • lsmc
                • May 2024
                • 2
                #67
                What is the specification of the battery you used friend? Another question, how did you solve the torsion of the hull caused by the engine torque?
