Tools
  • j.m.
    • Jul 2008
    • 838
    Here ya go!
    • properchopper
      rcgoatbuild@snotmail.com
      • 6958
      re :
      Here's a handy sander I picked up at Harbor Freight. It worked o.k. when I held it in my hand & worked the sanding end back & forth. It did however work way better once I discovered that when you plug it in & turn the switch on the belt spins ! lol
      • Dr. Jet
        • 1707
        That is the exact same tool I use to remove the "tongues" from my props. Put the prop on a shaft, spin it in a drill press or a lathe, and sand the prop to shape. Then thin, sharpen, and balance, as usual.
        Note:
        Plug the sander into an electrical outlet and turn it on before attempting to remove material from the work piece.
        • Meniscus
          Refuse the box exists!
          • Jul 2008
          • 3222
          LOL! funny stuff! (wondering if that was 220 he plugged into)
          • j.m.
            • Jul 2008
            • 838
            That's what I use to get my teeth going.
            • properchopper
              • 6958
              If you think that's good, last week there was a power failure. I plugged the unit in to the wall socket, put some cheese on the belt guard and a small mouse on the belt, treadmill-wise. Now there's a really fatigued mouse hiding out in my house somewhere. The cheese was delicious, 'tho !
              • j.m.
                • Jul 2008
                • 838
                Funny story.
                Not possible, but funny.
                • Avanti
                  • Nov 2007
                  • 1280
                  this sander is on sale for $22.95 until 12-26-08
                  page 22 of this flyer http://www.harborfreightusa.com/usa/...pe=RET&simple=
                  The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                  • Simon.O.
                    • Oct 2007
                    • 1521
                    Originally posted by Dr. Jet View Post
                    Seriously though, a good flat building board is important. Next are some X-Acto knives, a razor saw, an assortment of needle files, several sanding blocks, including one that is at least 22” long. Another important item is a good metal straight-edge. 12” minimum, but 24” or 36” wouldn’t hurt. Then you will need some squares (like a carpenter’s square), or at least some 90º triangles. Obviously, you will need an assortment of small wrenches, allen wrenches, and screwdrivers (flat and Phillips).
                    As for power tools, the most important is a Dremel tool. Next in line would be a drill press, and then a band or scroll saw.
                    For gluing, you need some weights, a lot of blue masking tape, and maybe some small clamps. Steal a roll of waxed paper from the kitchen.
                    This will get you started. After you get duct tape and WD-40 of course.
                    I must totally agree with this list!
                    I have a selection of lathes both wood and metal work to choose from and bandsaws, table saws, drill presses ( yes that is plural ) and these are all at my home.
                    Given all that I love to fabricate things by HAND(tools) and I get a lot of satisfaction from filing for hours before I use a grinder or linisher or other power tool.
                    Once the boat bits are made and there are other jobs to do I do enjoy a good run with a chainsaw, air-chisel, arc welder or 9" angle grinder from time to time.
                    • properchopper
                      • 6958
                      more tools
                      Two new toys for the collection. Belt/disc sander essential for wood boats [ like my under-construction VS-1]. The dual-chuck 18 V cordless is a real time saver;
                      $ 29.95 from Big Lots with lots of little goodies, charger & case.
                      WHOOPS;WRONG PICTURE !! See next post !
                      • properchopper
                        • 6958
                        correct picture
                        correct picture for above post
                        • j.m.
                          • Jul 2008
                          • 838
                          Nice amp!
                          (I guess...)
                          Me and my dad are big into audio.
                          • properchopper
                            • 6958
                            Nice amp!
                            (I guess...)
                            While it looks like a big power amp, it's actually a hernia-inducing, ninteen inch rack mount Power Supply !
