Thread size
  • Brothers 1718
    • Jul 2017
    • 132
    Thread size
    Does anyone know the thread size of this shaft?
    ProBoat Heavy Duty Flex Cable SW36, TC31.
  • Brothers 1718
    • Jul 2017
    • 132
    This is it on OSE:
    https://www.offshoreelectrics.com/pr...rod=hh-prb2052
    • dethow
      Wired Racing
      • Oct 2014
      • 1500
      This is the prop nut suggested.
      https://www.offshoreelectrics.com/pr...d=mc-94205A230
      Says "These work well as a propeller nut on 4mm threaded .7 pitch shafts"
      Have fun with that....
      • Brothers 1718
        • Jul 2017
        • 132
        I was thinking about cutting the straight end of the one i have shorter and I would have to cut a new thread into it afterwards so i was hoping to know if the thread size was the same as the cutter i found which is 10 - 24
        • pescador
          • 503
          I think it would be a 4mm die cutter. But you might not have to cut it, can you use a piece of fuel tubing between the nut and the prop to take up the extra room?
          Sent from my iPad using Tapatalk
          Namba District 16
          1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
          • Brothers 1718
            • Jul 2017
            • 132
            Hmmm. Thats an idea that never crossed my mind. Thank you very much for the suggestion I think I will do that instead of cutting my shaft.
