Miss Vegas Conversion #154287548
    Originally posted by Hastykiwi View Post
    Sweet idea. What is it I'm looking for?
    This is what Beaux suggested: https://www.offshoreelectrics.com/pr...prod=ose-80072
    But you could also go the shaft seal/saver route: https://www.offshoreelectrics.com/pr...d=aero-sts-125
    Here is one that is close to you: http://www.rcboatbitz.com/index.php?...oducts_id=2564
      I now see that you have just the Teflon coming up thru the hull, the flex saver would be the option then.
      • Hastykiwi
        • Oct 2017
        • 13
        Cool. Thanks for the help..
        • Hastykiwi
          • Oct 2017
          • 13
          Hey guys,
          massively slack finishing this thread, but here we go. Got the boat done, and took it for a test. The Nostradamus above who mentioned the amount of flex exposed was proven correct. Under load about 30secs into its second run it developed a whip in the flex cable, which buggered that up. Soooo, another flex cable later and the addition of another section of stuffing tube in the aforementioned spot, and we have a drive line that runs pretty smooth. It runs pretty well on a 442, and testing with a pile of props from 3 blade 38mm to 445's etc. nothing else quite gets to the same speed on 4s. We will see what happen with a bit more battery....when I get a bit more battery.
          Anyhoo, here a vid of its second run post rehashing the drive line. I must say for a hull that was setup for 50kph on Nitro, it is so stable at 80 odd.
          cheers boys.
          • FORT-26
            • Apr 2014
            • 239
            Awesome! Looks pretty solid. Good Job.
