Toysport Jolly "magic part"
  • Eodman
    • 1285
    Just received the part that Joseph Toth sent me. Its a wedge and you can see from the pictures were it sits!(between the drives)
    According to Joseph it makes the boat ride much more stable with considerable less bounce!
    I'll take a couple of pictures of the actual part that he sent and include measurements in case someone wants to try and duplicate it for their boat!
    My part is yellow so it should show up pretty decent on a dark background!
    We did it with a Bang!
    Cats Are Where It's At!
  • obrien
    • 1320
    its basically just a tunnel extension. Not only should it help settle the boat, but it may help top speed
    • Eodman
      • 1285
      OK the part measures 3 7/8 x 2 1/2 x 9/16.
      As you can see(I hope) it's a wedge!
      • Eodman
        • 1285
        Now I have a question - Joseph has said that I should just epoxy the part in place!
        Should I rough up the surface where the part sets to get a better adhesion?
        • z400
          • 1333
          roughing up the contact surface on both the hull and the wedge will help the epoxy bond to either surfaces.
          Z
          KBB34" Mono - Fast
          ToySport Triton- Not as fast
          • Ub Hauled
            • 3051
            Before you place that I think you should know that same people use trim tabs...
            just an FYI
            • Eodman
              • 1285
              Thanks I appreciate the thought! But I have to believe that the man who designed and built this twin Jolly believes that this is a better alternative!
              With this having twin drives I'm not sure where the right spot would be for trim tabs!
              • Avanti
                • 1298
                Kind of takes the place of a tunnel tab, obrien is right on the money. You might want to think about making it adjustable some how.
                The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                • Jeff Wohlt
                  • 2740
                  MTI does this on race boats only...we saw it and discussed it at Randy's shop (MTI) His was made of 2" teflon and has trim rams on it. Only good for higher speeds but says it works well. Tunnels the air and provides lift
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • bonewar
                    • 587
                    Awesome idea , I've been thinking about this type of trim tab for my twin maritimo cat. here is a pic of a real one on the boat. enjoy!!!
                    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                    • G Doggett
                      • 477
                      Thanks for the info and pictures.
                      I must make up something similar for my twin Jolly to tame the bounce.
                      Maybe if I make it from some flexible material like plastic sheet, or even carbon fibre, and attach it only on the front edge it can be adjustable on the rear edge with some screws or bolts like we do with trim tabs.
                      Hmmmmmm, have to get creative.
                      Graham.
                      • Eodman
                        • 1285
                        Well I had the cat out today after mounting the part on the hull and it does make quite a difference! The bounce is gone! You apply the power and it just lifts and goes .... Full Tilt Boogie!
                        But I'm still nervous running this thing, it handles well .... just not confident in my abilility in driving this fast!
                        But I love this boat!
                        • Ocean Racer
                          • 511
                          sounds good maybe it need a little more surface area to run on. wait which way do they usually bounce forward or back?
                          Failure is the First step to SUCCESS
                          • Avanti
                            • 1298
                            By bounce, I believe he means porpoise. Where the boat hops in and out of the water like a dolphin
                            • Ub Hauled
                              • 3051
                              Up and down
