Old member....new build....scale build...
  • ScarabChris
    • Oct 2010
    • 752
    Lightning fast shipping from OSE. I ordered the motor mounts and other parts on Friday and the USPS delivered on Sunday...hell Monday would have been fast.
    Modified two mounts to make one dual mount for 5" rails. This is going to work so much better. So easy to pull the motors if needed.
    • ScarabChris
      • Oct 2010
      • 752
      Some updates. Motor mounts in...came out nice.
      • ScarabChris
        • Oct 2010
        • 752
        Graupner outdrives filled with real marine gear lube. Took the lower units off and filled them from the top. Then topped off the drives from the top fill.The oil lever is only filled to cover half the upper horizontal shaft leaving room pressure increases.
        • Beaux
          • Dec 2015
          • 550
          Cool, that motor mount came out good. I like those quick change mounts.
          • ScarabChris
            • Oct 2010
            • 752
            #35
            Float test.....CG looks good but I can play with it with moving the main battery. I have the LiPo, ESC's, servo, RX battery and battery tray just placed in to see how she floats. No leaks and floats nice. If it performs half as good as it looks I'll be happy.
              • 7651
              #36
              Looks great Chris, nice job on the mounts.
              • ScarabChris
                • Oct 2010
                • 752
                #37
                Hanging out in the shop last night, enjoying a few cold beers and did some work.
                Steering servo mounted....I know it's a little tilted and it's driving me crazy. The beers had nothing to do with it, it's from leaning in the hull with my head upside down. LOL. I may remount it straight..
                Got a little creative with the water cooling. Used some aluminum tubing to make it a little cleaner looking. The outer scale exhaust pipes will be for the ESC's. I want everything coming out those 4 pipes. I run in salt water mostly and flushing with fresh water is easier this way. I have a rig with 4 hoses that slip over those transom pipes and back flushes with the fresh water hose on the dock. Fresh water pushed in the transom and out the bottom.
                  • 4335
                  #38
                  what did you use to seal the aluminum pipe against the cooling can elbows? The setup looks great.
                  • ScarabChris
                    • Oct 2010
                    • 752
                    #39
                    It's a really tight fit. Had to ream out the tubing a little and grind down the barb on the nipple just to get the tubing on there. Once I could muscle it on and off I used a little 5 minute epoxy to secure it. Also epoxied the tube to the mount right where the screw holds the mount in to give it a little extra holding power.
                    And I'm always 2nd guessing myself. On the port side motor I should have plugged the lower inlet on the water jacket and relocated it to the inside so it looks uniform with the other motor. Both water intake tubes between the motors.
                    • ScarabChris
                      • Oct 2010
                      • 752
                      #40
                      It's ready for a test run. I got it powered up at about 11pm last night and out it in the pool just to check it out. Pool not big enough....LOL.
                      Still have to mount the RX and route wiring, also waiting on an "InvisiSwitch" to arrive to finish the wiring. But it's ready for an actual test run. I'll toss it in the canal behind my house today.
                      • ScarabChris
                        • Oct 2010
                        • 752
                        #41
                        Making some progress. I did a few test runs and this boat is WAY faster than I ever expected. Like crazy fast considering it has geared outdrives.
                        I was only able to see this speed for a few seconds because on the first run I blew the gears in one of the drives. The gear mesh has to be absolutely 100% perfect for them to hold up. But I think I got them just right.
                        Then the 2nd run I lost an ESC, my water cooling mod leaked and filled one ESC with saltwater and that was the end of that. Smoke and came in one one motor. Lucky I had 4 of these SeaKing 180's. Three of the 4 were good so I made the repairs and now I have two working ESC's. If I blow another I'm going to bite the bullet and buy another Hydra 240 and use those (I have one already new in the box)
                        The gears....I found some gears on ebay, they need some slight modification to work but they work and are cheap enough. But the way this thing screams I can see gear replacements being a regular thing. I will likely look for some better quality scale drives in the future. The Arrow Shark drives are way to big and the TFL drives are to small but I think MHZ has a drive that is similar in size to these Graupner 820's. If only I could find some stainless steel gears for these drives.
                        I'll get some video on the next test run. After I get it dialed in I'm going to break it down and sand and smooth out and put a new coat of paint inside and I have MonoJeff working on a wrap for the outside.
                          • 7651
                          #42
                          What do the gears look like? If you hunt around you may find some hardened ones. I found all kinds when looking for my ERevo
                          • ScarabChris
                            • Oct 2010
                            • 752
                            #43
                            Pretty standard 90 degree miter gears. You can see a picture of the gears on post #2 in this thread.
                              • 7651
                              #44
                              So those are brass with a 5mm shaft? I was thinking of hardening those but if brass perhaps not.
                              I know how it goes with that kind of replacement/maintenance and it is a PITA. Best to avoid it for sure.
                              • ScarabChris
                                • Oct 2010
                                • 752
                                #45
                                Yup brass and pretty sure it's a 5mm shaft.
                                I found these on ebay, just need the shaft hole bored out a little and grind the overall diameter of the gear points down a little. They will work, I have 8 of them and haven't needed to use them yet but I will soon. LOL.
                                https://www.ebay.com/itm/BOSTON-GEAR...53.m2749.l2649
