27" carbon cat black edition build
    So I have this jig I made a while back to powder coat screws....because they are a pita. This makes it a snap.
    And I'm not so sure if I like it. I'm on the fence about it. I'm thinking the rod ends have to be black and so does the collet. Eeeek.
      • 4340
      #92
      Rod ends black. I like the green hex caps.
        Ok so....here's my plans:
        Rod ends black
        Small jam but on rudder and rod end by servo arm, black
        Collet black. Screws in collet green
        Hatch will be painted pearl black, green hatch bolts
          7 bearings installed in the strut with a snap ring retaining them.
            How's this look? I pced the collet and the rod ends. It's starting to blend better I think.
            • Mxkid261
              • Jun 2015
              • 734
              #96
              Do you have a small cutter you use to machine the snap ring groove?
                Yes. I had a carbide blank and I ground it into a very small groove cutter.
                • Mxkid261
                  • Jun 2015
                  • 734
                  #98
                  Cool if you could snap a quick pic of it that'd be awesome. I was talking to my buddy thats a machinist about doing this to my strut but he said they definitely don't have a tool that small and would need to make something lol. Are you spinning the strut in a lathe while you cut it?
                    Wait till this evening and I may have a easier solution for you. I ordered some parts that may delete the snap ring. Why not just send me your strut btw? I could do it one evening and send it right back. Now would be the time too because I have the lathe setup to do it.
                    • Mxkid261
                      • Jun 2015
                      • 734
                      #100
                      I suppose that works too. I may have to take you up on that offer
                      • Zondar
                        • May 2015
                        • 58
                        #101
                        Travis,
                        Send me your email address please.
                        bmcgrew1@sbcglobal.net
                        Traxxas Spartan, RCBB Zonda-R, Promarine MTR, Proboat IMP 31 v3, PB UL-19, Bonzai FE 47 Skater
                          Originally posted by Zondar View Post
                          Travis,
                          I thought I did but I'll send again.
                          I'll post a pic late but I wanted to tell you guys about a discovery I've made. You can powder coat over jb weld. I filled in the pickup hole on the rudder with jbweld and powder coated right over it. No issues.
                            I got some new straps in the other day. Much nicer than the eBay ones I've been using. The eBay ones are heat pressed together, I haven't had an issue with them. These are sewn with a metal buckle. I figured this boat deserves the best I can find. I will be using thee straps in my builds going forward from here.
                              • 4340
                              #104
                              Did you fill the hole in the spine of the rudder too?
                                Yes as much as I could.
