Radtek 45 steering issues
  • RuntheraceAMC
    • Sep 2016
    • 222
    I just finished a build of my Radtek 45 cat. Set up with SF240's and twin TP 4060 1950's
    I took it out today for the first time and could not get my steering issues sorted out. The boat wanders in one direction or the other. The rudder won't go straight when I release the wheel. If I start with it dead straight it eventually turns.
    I am using a low profile servo mounted vertically with a dual arm servo horn and push/ pull set up.
    During my build I noticed the rods and linkage to the steering were stiff so I disassembled and rebuilt it. I even changed the cables to a smaller cable to allow it to travel more freely. Any idea what I am doing wrong? Will attach pick shortly as soon as I get back from the lake.
  • RuntheraceAMC
    • Sep 2016
    • 222
    Ok. I can't figure out how to post pics. Has someone experienced this steering issue before? Please help!
    • Bigford
      • Mar 2017
      • 72
      Take your pic and up load it on photobucket.
      Copy the image link on p-bucket and paste it here
      • RuntheraceAMC
        • Sep 2016
        • 222
        I don't know what that is
        • RuntheraceAMC
          • Sep 2016
          • 222
          Figured it out
          • Silver954
            • Feb 2016
            • 69
            I went thru the same route using the dummy hydraulic arms and they look cool, but their function is terrible. The angles just don't add up, so you end up with limited steering angle and no accurate return to neutral. I think if the rudder mount of the hull went longer back, it would work better.
            I wanted speed so that set up was scraped and holes filled with gel coat. Went with regular rod and boot and I have never looked back, the functionality just can't be beat. I get maximum steering angle when needed and the rudder always returns to neutral with high accuracy.
            • RuntheraceAMC
              • Sep 2016
              • 222
              That is my thinking as well but it's a disappointing answer. I want to find a way for good looks and functionality to prevail
              • FE Frank
                • Apr 2014
                • 86
                Are the steering cable housings held in place with anything? Can't tell from the pic.
                If there not they need to be. I have my housings glued to the hull at the transom with a little bit of glue.
                Not a lot just enough to hold them in place out back. At the servo I also have them held in place with an aluminum block with some set screws. That set up is working great for me it has no slop and rudder returns to center.
                Hope this helps.
                Frank
                • FE Frank
                  • Apr 2014
                  • 86
                  Sorry can't figure out how to rotate the pic
                  • RuntheraceAMC
                    • Sep 2016
                    • 222
                    Thanks frank. I'll try that. I also realize that my servo only had 60oz of torque so I upgraded to a high voltage spectrum 175 oz low profile servo and set up my bec to run if of 3s. That may help it return to center but I am going to try that aluminum plate.
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      your hydraulic arms are way too far apart, you will have all sort of grinding issues, and the small servo dont have the torque to pull. you need to brint the hydraulics closer
                      • dasboata
                        • Dec 2010
                        • 3152
                        soft cables are just NG try the brass plated Sullivan and keep as much sheath as possible I can send you pics if you cant find them but cables need to be stiff not the soft galvanized cables but the brass looking ones
                        • Silver954
                          • Feb 2016
                          • 69
                          [ATTACH=CONFIG]152345[/ATTACH]
                          That's true but the radtek hull has a short transom rudder mount that's where the problem starts, you would have to shorten the hydraulic arms otherwise there is no range of movement
                          • RuntheraceAMC
                            • Sep 2016
                            • 222
                            Exactly my problem. Gonna try this be servo and see how it goes
                            • RuntheraceAMC
                              • Sep 2016
                              • 222
                              Dasboata,
                              Got the props. They are great. Except for the gash in my knee when the boat slipped while I was working on it. 😉 I'll buy some 1916's and 2015's too.
