Jet's Latest Hair-Brained Idea
  • JimClark
    • 5913
    #61
    Randy can i get the measurements of the drop sponson? How bout a pre order?
    Jim
    Billy Graham
    • RandyatBBY
      • 3943
      #62
      Jim
      It is 15.5 X 8 inches, I have you first on the mental list.
      Randy
      BBY Racing
      • RandyatBBY
        • 3943
        #63
        I did the test pull this morning, I was impressed with the molds sofar. the bow fit real good the transom on the deck mold needs a little more work. There is a picture on my site.
        Randy
        BBY Racing
        • Sneasle
          • 202
          #64
          Wow, that looks great. I'm in for at least one when you get done.
          • JimClark
            • 5913
            #65
            Randy in the pictures it looks like the side of the sponsons pretty much go straight down. Any thought of making it a more conventional looking sponson like this?
            Billy Graham
            • Sneasle
              • 202
              #66
              I see what you mean Jim.
              I do see some down slope there, but looks like.. oh.. about 1/2" of vertical before it starts the slope. Would it cause much of a difference? I guess it depends on where the water line sits when the boat isn't moving. If the water line is higher, then I guess it would take longer for the boat to 'break' free and get on plane.
              • Dr. Jet
                • 1759
                #67
                Randy,
                I like the look of your dropped-sponson hydro. As Jim pointed out, the sponson sides seem to have a large vertical section, but I know that most of this gets cut off before joining the hull halves. I checked out your photo of the test-pull and it looks good. My only question is: Did you leave enough room (vertically) to fit a motor in there? I know on the MTH, there needed to be a "bubble" in the hatch to allow room for the motor.
                I’ve been working on the drawings for the ’77-’81 Atlas, and a couple of things have come up.
                First, at 1:25 scale (to match the Allison engine I have) is just a bit too small. It works out to just under 14”. Additionally, fitting the Chinese outrunner in there will be a challenge.
                Second, I’m still not 100% certain which engine the ’77 – ’81 Atlas used. The ’82 Atlas used a Merlin, and I’m beginning to think the earlier version used that engine as well. I’ve done a lot of research so far, and other than some grainy photographs of the exhaust stacks, I just can not seem to find a conclusive statement anywhere. If it is indeed the case that it used the Merlin, then I may go with 1:24 scale. I have a 1:24 scale Merlin in my Box-O-Stuff that I can use. That way the boat will be about 14-1/4” long.
                Still, at 1:24 scale, it is going to be a challenge to hide the outrunner in that hull. I think it can be done by placing the motor horizontally and using a U-joint as the motor/shaft connector. Look for a cool solution from the Doctor on this.
                A nation of sheep breeds a government of wolves
                • JimClark
                  • 5913
                  #68
                  Doc it was for sure a Merlin
                  Where did you get a 1/24th scale merlin
                  Jim
                  Billy Graham
                  • Dr. Jet
                    • 1759
                    #69
                    Jim
                    Thanks for the info Jim, I was certain somebody here had the facts.
                    The 1:24 Merlin is a resin-cast model I think I found on ebay. He may have included his contact info in the kit, I'll check it out when I get home tonight and post the data if I find it.
                    • Dr. Jet
                      • 1759
                      #70
                      Jim,
                      Do you have photos of the Atlas engine/engine bay?
                      • RandyatBBY
                        • 3943
                        #71
                        Ya know I had not thought about that If you look at the picture I was using that part is below the water line. It could be done, I want to keep the rub rail at the seam a little big to keep the join strong. But below that we could change to make it more scale.
                        Randy
                        BBY Racing
                        • JimClark
                          • 5913
                          #72
                          Here Randy
                          Billy Graham
                          • JimClark
                            • 5913
                            #73
                            Pics from the 82 restoration it should be similar
                            Originally posted by Dr. Jet View Post
                            Jim,
                            Billy Graham
                            • RandyatBBY
                              • 3943
                              #74
                              Thanks Jim, I went to your photo's and looked at the pictures this one caught my eye.
                              Randy
                              BBY Racing
                              • JimClark
                                • 5913
                                #75
                                or this one
                                Billy Graham
