head of the river cat hull thread
  • amo123
    • Jul 2009
    • 49
    #856
    so scratch the 8xl and go with 12xl or 13xl?
    savage 4.6 - blackjack 26 - e-revo - HOTR 32" Apparition - blade cp - blade sr - trex 450 -
    • suckmywake
      • 191
      #857
      Here is some data from running my HOTR cat with different motors and props. My set up started with an ARTR HOTR cat. Twist was removed from hull. The sponsons still have some angle. I added a layer of 6oz fg cloth to bottom as far forward is I could reach. I added another layer around motor mount. The front was foamed. The strut was drilled out for SV type bushing and I am running .78 piano wire drive. The strut is set at gap of 1/8” above sponsons. The COG is 8.5” from sponson end. I run 6s1p on 2 Turnigy 3s 5000mah 35c/45c batt. All run were with same batts. The esc is 200a Himodel type w/bec. (ESC setting 0deg timing and PWM 8k on all runs)
      Motors
      Feigao 13xl 1339kv
      ARC 36-55-2 1400kv (This looks to have wye windings)
      Neu 1515 1.5y 1500kv
      ARC 36-75-1 1680kv (This looks to have wye windings)
      ...................................( .... @ speed indicated ....... )
      .........Motor......MPH ... RPM ... Amp ... Volts ... Watts ... Peak Amps
      X440
      ... ARC 1680kv... 55 ... 35046 ... 74 ... 23.46 ... 1737 ... 139
      X440/3
      ... ARC 1400kv ... 51 ... 28409... 55 ... 23.80 ... 1318 ... 106
      ... Neu 1500kv ... 53 ... 31250 ... 65 ... 23.29 ... 1521 ... 128
      ... ARC 1680kv ... 59 ... 34722 ... 74 ... 23.66 ... 1754 ... 153
      X442
      Feigao 1339kv... 52 ... 28089 ... 58 ... 22.68 ... 1325 ... 109
      ...ARC 1400kv ... 52 ... 28190 ... 55 ... 23.81 ... 1326 ... 110
      ...NEU 1500kv ... 59 ... 30737 ... 80 ... 22.98 ... 1844 ... 137
      ...ARC 1680kv.... 64 ... 33783 ... 85 ... 22.77 ... 1945 ... 166
      Temps after running 1000mah
      Feigao 1339kv..... Motor 106 F.......ESC 102 F
      ... ARC 1400kv .... Motor 87 F.........ESC 99 F
      ... NEU 1500kv .... Motor 117 F ......ESC 125 F
      ... ARC 1680kv .... Motor 114 F...... ESC 121 F
      Temps after running 2000mah
      ARC 1400kv .... Motor 125 F ..... ESC 120 F
      ARC 1680kv .... Motor 125 F ..... ESC 160+ F (HOT)
      Notes on temp.
      Feigao motor temp. continued to rise up to 140 deg. F just sitting. I take this as stator temp is way higher than the can temp. I never trust can temp on 2 pole motors. I always do 10 second finger test on end bell of all motors.
      Neu motor was run with silicone SV type cooler. Not the most idea cooler. This is all I could fit with motor mounts.
      The thing I found most interesting was the feigoa peak amps was lower than all other 4 pole motors. I always thought a 2 pole had a higher peak amp load than a 4 pole.
      • 785boats
        Wet Track Racing
        • 3169
        #858
        Excellent info there. Now maybe some people will understamnd why their 90A or 120A ESCs fry with these sort of setups.
        Like you, I like to run the Himodel 200a as it is twice the current capability of what is being used.
        Just one thing though. Zero timing is not the best for these motors. Any chance of doing another set of tests with the timing at least 7 degrees. Some even suggest up to 15 degrees. You will probably find less heat & more speed. I know I did at 7 degrees on an 8Xl on 4s. I've no experience with the other motors though.
        Would be interesting to see the difference.
        Cheers.
        Paul.
        • suckmywake
          • 191
          #859
          Yes I plan on increasing timing to try to get more speed. I am first going to trying to get ESC temp down for longer run time. I have an ideas that is going to seem wrong to a lot of people about water cooling a electronic device. I would like to keep on using these esc and not switch over to my CC 240A. I ask Dave @ Lightflight a while back about timing on ARC motor and he said keep @ 0deg. If any one has suggestion on timing please let me know. To get info on timing is one of the reasons I posted the wye winding info on ARC motors. I think all motors execpt Feigao can take more timing. Also I would like any input on PWM of ESC. I once read that incresing PWM of ESC helps temp of esc for a higher temp in motor. Does any one know about PWM of esc and can explain it to me?
          • MadMac
            • Sep 2009
            • 11
            #860
            Any down fall to using a fiego 7xl with a 180 esc and 4s30c pack 2) 2s30c in series
            What prop would you use.
            I am asking because I have a local guy with 7 xl motor for 30 bucks.
            Mac
            • Rumdog
              • 6453
              #861
              Small props is the downfall. Prop up too much and you'll be pulling some major amps! I'd start with a x440. You may end up as big as a m445. Watch the temps!!
              • tomstoys2
                • 581
                #862
                Last week on vacation I decided to try some different props.
                Stock HOTR square flex drive.
                SV27 motor
                70A ESC that came with the ARTR boat
                2 - 2s 5800 Turnigy (4s)
                I was able to get 40.9 mph on the GPS with an X440/3 but after about 3 min. of run time the speed controller stopped working. Temps on both the ESC and Motor were around 179. Way to much prop for this set up.
                I need some suggestions on a new set up.
                I have a Turnigy 120amp ESC
                I would be happy with low 40's
                I Want to run 4s
                These are the motors I have laying around that I would like to use.
                Nemesis 540 11xl 1516 Kv
                Feigao 540 12L 2,159 RPM
                Stock BlackJack Motor and ESC.
                I'd like something that will give me decent run times and won't be running full throttle all the time due to the running conditions.
                Anyone have any thoughts if either of these motors would work better?
                Thanks,
                Tom
                Update on this post, SV27 motor bearing went that cause the ESC to fail
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #863
                  SV27 motor
                  I Want to run 4s
                  Thanks,
                  Tom
                  I have several of these hulls and several configurations all around 40-50+ mph. It's a great sport setup speed for them IMO.
                  If you're going twin: (this is my setup on Das Boot - a 32" HOTR)
                  The 2100Kv's on 4s w/a pair of K40's and 120a amp escs, use a soft start if you can, you will keep the amp draw and heat much lower. Most heat is created during acceleration. You can use the Sea-King 120a ESC to pair with the Turnigy 120a. They are both hobby wing. Just make sure they are both version 2. Might even get away with a pair of 90a esc's since it's a twin.
                  I also have a pair of 2700kv's on 4s w/32mm props going about 55 tops w/60a ESC's. It's a fun setup, but flips real easy at that speed.
                  I have two more of the same size hulls I'm building for the same purpose as you mention. Sport, 40+ mph and good run times. There's a few guys here with some good setup info on this hull.
                  If you are going to stay single:
                  Get a T180a ESC and a Leopard 2200Kv (or Castle) and 38 or 40 prop on 4s
                  Hope this helps!
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    #864
                    I'm suprised that the sv motor couldn't handle that 440/3. Out of themotors you have I would say the nemises xl motor would be best. The lower kv and the longer can will fair better in a heavy boat.
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1679
                      #865
                      Oh is Toms boat a twin?
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        #866
                        I don't think so, I was a bit confused at first when I wrote my response. I think it's a single.
                        • tomstoys2
                          • 581
                          #867
                          yes, it's a single.
                          I was surprised the SV27 motor didn't handle it either.
                          • tomstoys2
                            • 581
                            #868
                            Thanks guys. I'm going to try the XL. I figured on 4s the 120A ESC should be able to handle it. I'll post the results.
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1679
                              #869
                              Keep up posted!
                              • Alfa Spirit
                                • 2131
                                #870
                                Nemesis 540 11xl 1516 Kv and 6S (2x3S) batteries
