head of the river cat hull thread
    • 9479
    #841
    did ya get a video of that 5s run..?
    • tiqueman
      • Jul 2009
      • 5669
      #842
      No I did not. I could re-set it up and get one though. It was in a 32" cat, but not a HOTR. Ive since gone to a 9Xl... why you ask.. I have no idea.. something to do. I figured I could run it more on 5S and be closer to 50 w/ out pulling a lot of amps. Im running an Etti 150 OPTO That was 4 months or so ago... how many times have I run it on 5S? NONE. How many times on 4S? Maybe 2... Im a discrace to the FE world sometimes.....
      EDIT, just checked my notes. 5S Using a 3S1P 5000 30C and a 2S1P 5000 30C and a 442 was 54.8mph. And in my notes I have , " didnt check temps but a light puff of smoke came out when hatch was removed. Nothing felt abnormally hot."
      • Simon.O.
        • Oct 2007
        • 1521
        #843
        To me you are close to role model.
        I run close to that setup in my big cat which is a touch bigger that the hotr 32
        I have 4500mAh 30C packs feeding a 9XL via a Mystery 200A ESC
        The best prop I have run so far is a 440/3 that was touched up by Scott (ozzie-crawl)
        It is better than a 442 but I have yet to try the 640 or 642 with the new strut settings. The 440/3 blows it over so gawd knows what the 6xx props will do.
        9XL on 5S to a 442 or a 440/3 should run warm but not hot.
        • KillerDave
          • 370
          #844
          Originally posted by Simon.O. View Post
          I run close to that setup in my <a onMouseOver="javascript:window.status='big cat';return true;" onMouseOut="javascript:window.status='';return true;" href="http://phatological.info/?v=4%2E03&ss=big+cat">big cat</a> which is a touch bigger that the hotr 32
          I ran mine with a Propshop 4216/3 it hit 68mph no blow-over but it did have two 3s 5000mAh Li-Po's in it to keep it down.......
          No idea what it will do in your setup.... but, if you remember, my setup was all wrong and it cooked my packs!
          HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
          • nikos222
            • Jan 2010
            • 25
            #845
            Finally, i think that the upside - down servo works good !!!
            This is the first run with my new cat. Low speed, just for testing.
            Basic setup :
            Motor : 2700 rpm/V, Bat : 2 x 3s parallel 3000 mah, Esc : 120A,
            Prop : 440.
            I have to try a bigger prop. Maybe i need a 442 or 445.
            • nikos222
              • Jan 2010
              • 25
              #846
              Another choice.
              2 x 3s parallel, prop 445
              How it seems ?
              • MadMac
                • Sep 2009
                • 11
                #847
                Welcome to the forums Mad Mac! Your post started out on the right track and then went a bit amiss. An 8XL is a wonderful set up and on a 442, youd start very close to if not perfect. However, your on the right track w/ the 2 - 2S lipos in series as 4S. You will get by on the 120, but your really close to maxing it out. On a 442, within 10A or so. An 8XL is not a good idea on 6S, if you want it to last. And certainly not a sport boat or race boat set up. It would be a couple SAW passes, just to say "Wow!"... You will have a mid 40s boat on an 8XL on 4S which the HOTR hull will handle wonderfully. Im curious to know how your RTR runs, as Ive been asked by a few how fast it may go, and have noly guessd low/ mid 30s on a 3S set up, which is what I rhink is recommended.. at least in the set ups Ive seen as RTR. So keep us posted and good luck w/ the hull. You will without a doubt love it.
                Well the 4s on the stock motor smoked the motor 2 passes around the pond and poof.......the magic smoke got loose. She hauled the mail for a minute or 2 but then, turned into a decoy. So now I have a turnigy 180 amper coming and still looking for a good motor (got any ideas somewhere quick.) Props I have a few that I may lab myself since I can do the 1/1 props here in the shop. not much different just a lot smaller.
                We shall see how the 8xl will go on the 2-2s30c packs in series.
                Thanks for the pointers fellas
                already having fun with it.
                Mac
                • amo123
                  • Jul 2009
                  • 49
                  #848
                  reviving thread.....32 apparition build
                  well gots my 8xl and a swordfish 120 with 6s x642 prop and am wondering where to set up my cg? i have foamed the front and glassed in kevlar. everyone uses cf so i thought i would be different. i horribly botched up the look but the strength is still there....back to the cg question any ideas or recomendations? also should i be runnign this prop or should i get some thing else?
                  savage 4.6 - blackjack 26 - e-revo - HOTR 32" Apparition - blade cp - blade sr - trex 450 -
                  • tiqueman
                    • Jul 2009
                    • 5669
                    #849
                    Start 7.5 to 8.5 from the back of the Sponson... not the transom. It should be somewhere within those numbers.
                    EDIT. Oh, prop... start a bit smaller.. maybe 442. Mine runs better on a 442 than a 642. Cooler and a bit faster.
                    • tiqueman
                      • Jul 2009
                      • 5669
                      #850
                      Your also going to be a bit over your rating for your 120A esc on a 642. You may be around 130-135. That may not be a good thing.
                      • tiqueman
                        • Jul 2009
                        • 5669
                        #851
                        Oh crap.. and you CANNOT run a 8Xl on 6S... and certainly not a a 120A esc. IN less then 30 seconds you eill have a burnt motor, esc and a boat that is filled w/ black soot.
                        8XL is a 4S motor... maybe 5S for quick two pass "lets see what it will do"./ But a 120A esc will not handle 5S on an 8XL without problems. Not trying to shoot you down by all means.. just want you to have happy boating.
                          • 9479
                          #852
                          See Mancs post.. 8XL on 6S.. no more motor.
                          come on, it's only smoke..
                          • tiqueman
                            • Jul 2009
                            • 5669
                            #853
                            LOL heck, I can get passed the smoke.. its the nasty funk that smells for a year thats hard to overcome
                            And I edited that quote from above.. he ran 4S and smoked the esc..... But still, 6S will kill an 8XL.
                              • 9479
                              #854
                              That's a smell I wish I've never smelt
                              • norbique
                                • 356
                                #855
                                It all depends on the KV rating of the motor. The 12XL or 13XL will run nicely on 6S, that's what I'm planning into my scratch cat.
                                Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
                                - Mark Twain
