head of the river cat hull thread
  • DISAR
    • Aug 2007
    • 1137
    #541
    Here, pls look in post #15
    http://forums.offshoreelectrics.com/...read.php?t=271
    http://www.rcfastboats.com/
    • KillerDave
      • 370
      #542
      Originally posted by DISAR View Post
      Thanks for that, Not just #15 but there is alot of info I can use on there! Thank you....
      HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
      • domwilson
        • 4411
        #543
        Here ya go... http://www.rcboataholic.com/fe_calc.htm
        Government Moto:
        • DINO7
          • Jan 2009
          • 165
          #544
          new color for mine.
          H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
          MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
          BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
          • Rumdog
            • 6667
            #545
            Is anyone running an offset rudder at all?
            • RCprince
              • Jul 2007
              • 1684
              #546
              Didn't they at one time have red and yellow hulls also.
              Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
              • Rumdog
                • 6667
                #547
                I think they still do
                  from time to time...
                    Originally posted by DINO7 View Post
                    new color for mine.
                    What motor sir? and, KV, batteries and prop please???
                    Nice boat, I have seen it on other forums too.
                    • DISAR
                      • Aug 2007
                      • 1137
                      #550
                      Ray, I've seen this boat running, very nice. The setup is
                      Motor Medusa 36-50 2200kV
                      4s Rhinos
                      ESC-chinese ELF 100A? Holds very well
                      Props 42-45 mm
                      • KillerDave
                        • 370
                        #551
                        Has anybody done a twin 540 build?
                        I have been thinking of doing something like...
                        10l Feigao X2
                        ETTI Navy 150 X2
                        Octura X442's
                        Running on 2 4S Li-Po's....
                        What do you think???
                          I have 2- Arc 3655-1turns 2800kv (4-pole L-size can), 2- Skywing esc's either 100 amp or 200 amp units I modded with waterproof and cooling, I've got both.
                          L & R .150 octura cables with 3/16" stub stepped down to 1/8".
                          I'll use some older Hyperion cells 3S, 5000's to start with Venom 3 blade props 32mm &36mm...
                          • t0ny1ee
                            • Jun 2009
                            • 6
                            #553
                            I started my twin drive build yesterday. Going along the lines of Killerdave`s build with 2 4cells lipos and octura X442`s (counter rotating) but with 2 7XL motors.
                            Got the outdrives mounted (from tough racing) and then found out I`ve bought the wrong size stuffing tubes - awesome!
                            I haven`t got the esc`s sorted yet but I might go for 2x himodel 200amp(modified with water cooling). I already have an ETTI 150 (which is easily the best esc ever owned) but its cheaper to buy 2 himodels than one more of these.
                            And now I have a question, there are 2 types of himodel 200amp esc. The 4-8cell version with bec and the 3-7cell version with no bec. I have already fried one of the first type (which ran very hot even with water cooling at 118amps) and have another one ready to try. Is there any reason why the 3-7cell version might be better, I`ve noticed that quite a few people use them?
                            • KillerDave
                              • 370
                              #554
                              Hey there! Don't go building one what I said!!!! I am still running blide and need help along the way as to what will work!??
                              Why are you going for the 7xl's?
                              Is there anything wrong with my set-up plans??
                              I've not started yet as my hull is still being repaired but Christmas is comming and I'm hoping for some parts!
                              Any photo's of your build????
                                Don't use the BEC and don't use over 4-6S batts. I run them, same as my Skywings too. I just don't use the BEC. Remove red wire and use UBEC or RX pack.
                                It'll save you money in the long run. I don't know why they rate that esc at 8S, silly.
                                As soon as I get more thermal RTV silicone I'll show you my monster cooling and esc rebuild (only for Opto Versions!) For these I'm using $40 Mystery esc's from Fleabay Might as well get them there, $40 to your door??? Why bother with Himodel, same esc pretty much...
                                Monster ESC build coming soon....
