Originally posted by focused
View Post
head of the river cat hull thread
Originally posted by Dr. Jet View PostThere is nobody on this planet that knows more about cats than Fluid. You might be suprised if you saw one of his cats in action. You would do well to heed his advice.
Good advice is always welcome , i cannot know everything
Michiel.----------------------
sorry guys been away. to answer 1 question i think my cat weighs in at about 2.3 kg or 5 pounds, alot depends on batterie size
i havent tried to turn my boat at full speed yet i havent ran it on a proper course to try it.
i tried a 6xl on 4s with 120 amp esc and yep it killed everyone so i wouldnt recomend it unless you were just trying for saw type runs. but then you would pobably be a lot better going the low kv high volt option
scott
Finaly caught up with you here Ozzie.
I'm running the SV27 motor & ESC in mine on 4s with an X645 prop & I think it will stay that way because the club is setting up a restricted Cat class with those & the proboat Blackjack motors & ESCs. Should be fun.
Just want to let everyone know that I just found a hairline crack down each side of the hull where the top & bottom join. Doesn't go all the way through but it's something to watch out for after a few runs.
Scott.
Our club is having our yearly open day & swap/sale meet on saturday if you guys want to make the trip. Lots of bargains usually. There'll be clubs from North Coast, South Coast, Logan, Northlakes etc there. As well as Suppliers & manufacturers. It's an open invitation. To anyone in the area, here's a link to our website for the info.
All the best.
hey good to hear from you paul, i cant make it up but will let geoff know he mite come up. good idea to run a stock class keeps price down and closer raceing you probably should look at a fiego sv 27 motors hard to get
cheers scott
Paul, hey mate, i ran mine on the weekend with the hyperion esc along with an ammo 2300, i ran an x640 prop and man does this thing move, its running a little wet when there is no chop but for racing it should be the ticket... see you at the swap meet on saturday, should be good..Originally posted by 785boats View PostFinaly caught up with you here Ozzie.
Scott.
All the best.
Paul.
Benwill try till smoke?
www.slaughtermotorsport.com
My boat is going to be setup like your. Where did you get that prop? Could you give me a link? BTW, is that 5000Mah per pack or is that total of two packs in series?Originally posted by focused View PostMy setup is :
Motor, Feigao 540XL9
Esc , ETTI 125amp
Lipo , 2 x Zippy H 5000Mah 3s
Speed , 58mhp with 42mm K prop hope to reach 60+ with a 42mm metal prop
Time of fun . 6 to 7 min.
I think its best to put all the head of the river cats in one place so i`m in and if you need help just ask.
grtz
Michiel.
Hi everyone bought a bare hull and need help setting up in dual formation - I want to run with either twin 2300 Ammos or Feiago 8xl's
ESC's will probably be 2x 100 Xpowers or CC 120 Hydra unless some can advise me on using a single esc like 240CC Hydra
> What motor mounts do i need to fit in sponsons??
> Where's the best positioning for mounts??
(please include some sort of measurement for me to follow
> As i have plenty of .150 flex cable (for my BJ26 & SV27) I would like to use these in this build - so apart from obviously using the SV27 strut can anyone recommend other struts drive i could use?
I'd really like something that looks like the stuff from swissmodelpowerboats or MHZ powertrimm drivers if possible without the huge cost - suggestions please??
> I have plenty of props Cf & Octura but I guessing i will need counter rotating props??
and lastly is it recommend to reinforce the hull internally with a thin layer of F/glass or carbon fibre??
Huge gratitude if anyone can assist me is this build thanks
yes will using Lipos from 4 to 6s 5000Mah or more if i can get them
Two XL8 are unnessesary big , 2 540L will be enough
I would 120 or bigger
homemade one`s from carbon or epoxy plate
that i dont know
Struts from LINK LINK
yes and counter rotating flex cable
first layer of carbon then finish it with a thin layer of f/glass
grtz
Michiel.Last edited by focused; 11-07-2008, 02:31 AM.----------------------
Thanks for the answers - Really need to know where to install motor mounts - As i would rather buy mounts which should i use?? and from where??....
who ever has one of these hulls can they measure from transom to front of motor mount if possible
OK then - I'll probably go with 2x cc 120 Hydras or make use of the two Xpower 100 ESC I have lying around, they where good in my SV27 with 2300Kv Ammo setup.
Counter rotating flex cables? Where do i buy them? I've never seen these - then again I've never looked for then before.
Thanks again!!
See the thread you started..."A quick temper will make a fool of you soon enough."
, you have to step of the throttle and slow down .
and it didnt like it .
