Supervee 27 new build help
  • Ivabiggen
    • May 2017
    • 2
    G'day,
    I've acquired a bare SV27 hull with only the strut and stuffing tube attached. This will be my first build so looking for advise to get this thing going PROPerly. Only played with NQD jet boat and a Feilun 011 before now so I'm ultra keen to see this one on the water.
    I have a spare 3660 2300kv motor, a watercooled 100a esc and a spare 437 brass prop lying around ready to bolt in. Besides these I'm needing to purchase everything else. I'll be using a Flysky IT4S tx and FS ia4b RX.
    So, tapping into the expertise on this forum, can I please have suggestions on what size rudder/bracket, turn fins, trim tabs and flex drive shaft to purchase?
    I'm happy to purchase all new gear including new strut and stuffing tube too.
    I've seen this EBay offering that include all parts I need such as this https://www.ebay.com.au/itm/282394514923
    Is this a good option to start with to get some parts and then upgrade others? Which parts are worthy or not?
    Anything else I should consider to make this thing a reliable, responsive and an exciting boat will be greatly appreciated!
    Thank you in advance
  • TheShaughnessy
    • 1461
    welcome to the forum, you will find everything you need on this sub-forum made just for the Aquacraft SV27 https://forums.offshoreelectrics.com...shless-Q-amp-A or
    • Ivabiggen
      • May 2017
      • 2
      Thank you, I've had a good hard look through 30+ pages of information but couldn't find the exact info I'm looking for.. eg. Rudder, turn fin and trim tab lengths. There plenty of info that's for sure which I'll be referring back to in future no doubt!
      I also started this thread in hopes to give a direct reference for the measurements needed to source the parts for any other persons in my position starting with a bare hull.
      Hopefully someone will respond with at least the factory dimensions for the aforementioned items as a start point that I can refer to??!
