Need help with fixing a build???
  • Kkingx1
    • Aug 2016
    • 19
    I have a p mono pursuit... t-180 esc, castle 1515 2200kv motor, with spectrum receiver, and x442... running 2 2s in series waiting for 4s to come in to run in parallel..
    but anyways...
    After running full throttle for about 1/2 a lap the throttle just losses all power... I have to release the throttle completely to get the boat to get power back to the boat... and the motor and esc are extremely cool? I've only done a 1/2 lap...
    What I've done to try to fix it is try two other escs (hobbywing 160 and even just a 120) and get the same results... I had an extra castle 1515 2200kv same as the old one but this is new in the box... and got the same exact cut off... I've changed out the receiver 3-4 times only one was new outta the box.. but same exact result... I went as far as changing the servo because I've already changed everything else... same result... this set up did work for 2-3 weekends the just stopped.. I don't know what to do after all of that?
    Does anyone know where to look now? What to check?
    Thanks for any advice given
    • 4338
    Your batteries are the common factor in all of your troubleshooting. Were all of these tests run on the same 2S packs? How old are they? What are they? Have your tried different batteries?
    • Kkingx1
      • Aug 2016
      • 19
      Yes i have tried multiple battery packs from 30-100c and ran those same batteries in my other p-mono aeromarine (33") titan 40!
      • Kkingx1
        • Aug 2016
        • 19
        The only thing I can think of is go back and make sure I have good solder joints and connections however that wouldn't explain why I had working motor and esc prior to all this
        • Tamelesstgr
          • Jun 2014
          • 1512
          What version of the 180 are you using? Turnigy, Seaking? There was a thread a few weeks ago about a common esc problem and a bad batch if i recall?
          NEVER SATISFIED RACING
          Fine Design 32 V-Hull 4082+6s
          • Tamelesstgr
            • Jun 2014
            • 1512
            What setting is the LVC set at on your Esc?
            • Peter A
              • 1622
              Try turning off the lvc and set the timing to 0*. I had a similar problem in my pursuit going form a v2 T-180 to an OSE Raider 150. Motor in mine is a TP 4050 2050kv, it would work with a 442 but put on a 445 and it would cut out after about a lap, and I had to let go the throttle and go again. It was only going into lvc mode though not cutting right out.
              • Kkingx1
                • Aug 2016
                • 19
                Thanks! I'll give that a try tonight! Think I turned the Lvc to the lowest setting that isn't off and the timing at 11*... I'll make those changes tonight and hopefully we will be back in action! Thanks!
                • martin
                  • 2881
                  I believe these very problems were discussed recently on the 180a v3 esc, they tried quite a number of new esc they had & all of then were the same re shutting down. They also tried switching the lvc off to no effect & all the other settings like different timing, I seem to remember that someone from Hobbywing came on & said there were possible software problems with some esc.
                  • Kkingx1
                    • Aug 2016
                    • 19
                    My t-180 is a turnigy... I know they're pretty much the same... would it have the same issue?
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      Here is the thread, pages 3 and 4 detail the recent issues:
                      https://forums.offshoreelectrics.com...SeaKings/page4
                      • Kkingx1
                        • Aug 2016
                        • 19
                        Thanks for the link
                        • Tamelesstgr
                          • Jun 2014
                          • 1512
                          I have the Turnigy 180 as well, but havent experienced any issues. I think i turned my LVC completely off though.
                          • Kkingx1
                            • Aug 2016
                            • 19
                            I'm going to try that out tonight when I get off... hopefully it works!
