Pro Boat Formula Fastech Jet Drive Project
  • Viking
    • Jul 2008
    • 133
    #61
    Hi Jesse;
    "Great video! looks like fun! was that full throttle? I was thinking of putting in a sc 700 or like you say XL brushless. I will be watching for more videos under bl power!"
    Some of it was full throttle, it is a lot of fun, remember to keep the boat up stream so if it dies or turns turtle you can catch it.
    ---"How is that hull? would it be worth laying down some good sturdy fg before construction? Do you have any shots of the transom? How do you mount up that jet?
    --- YES it would be worth a layer of glass or carbonfiber on the inside. Not just the bottom, the strakes make the bottom very strong. I have a couple of major cracks in the sides of the hull. Study the instructions for the Jet, drilling that huge hole in the transom is a major move. Both of the heavy gray plastic pieces go on from the outside then the white water duct goes on the inside. So cut and fit the housing and nozzle(gray parts) before cutting the hole in the bottom of the boat.
    Leave the Vee hull alone ! The less boat in the water the better. A big flat pad is just drag.
    Viking
    That Viking www.How2RC.com PULSO
    Home made 36" DeepVee 50mph
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      #62
      Viking
      I would have to disagree. Not only would that be wrong, the flat pad makes it easier to marry the jet drive to the hull.
      Originally posted by Tips & Info
      The Shallow Vee has a much flatter bottom which when at full speed has less of the hull touch the water. This make the Shallow Vee faster. But the Shallow Vees tend to slide around corners, instead of carving the turn. Below is a picture of a transom with much less angle.
      If a flatter v is faster than a deep v, then a flat spot should be "less" drag.
      Source
      • Viking
        • Jul 2008
        • 133
        #63
        Flat Spot
        Hey Diego;
        You are quite correct the flat spot would make it easier to install the jet.
        The shallow Vee is faster than a Deep Vee with a prop for the simple reason that it is easier to keep the hull out of the water.Less drag.
        With a Jet boat if the hull is out of the water, it is not picking up water and so there is no thrust. A Jet can't be aired out like a prop boat the Jet intake and so some of the hull Must be in the water to maintain thrust.
        No, Yes, Maybe???
        Viking
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          #64
          True, but lets take a look at surface area for just a moment.
          Look at the picture... I'm no math genius, but I see less hull in the water. take that number and multiply by the length of the hull, I see a huge amount of difference.
          • Jesse J
            scale FE enthusiast
            • 7241
            #65
            I am on Diego's boat on this one. Also, flat bottoms support weight better by spreading the displacement out over less surface area as the drawing shows. The mere fact that it would help the intake alone, not to mention we are not talking super speed boat, almost makes it worth it. I was picturing flattening just the back half or so, kinda like the Fastech. The EV tends to flop around a lot, being severe deep vee and so top heavy.
            "Look good doin' it"
            See the fleet
            • Diegoboy
              Administrator
              • Mar 2007
              • 7247
              #66
              I wonder why all jet ski's, seadoo's, etc... are NOT deep V hulls?
                • 7277
                #67
                When is this thing going to be done so I can buy it.
                • Diegoboy
                  Administrator
                  • Mar 2007
                  • 7247
                  #68
                  Doby, So you want this boat AND the Graupner rigger?
                    • 7277
                    #69
                    Nahhh, not the rigger, its cool but not my thing.......the jet drive IS VERY Interesting!!!
                    • Diegoboy
                      Administrator
                      • Mar 2007
                      • 7247
                      #70
                      That's cool, because EyeKandy is first in line for the Rigger!
                      • Viking
                        • Jul 2008
                        • 133
                        #71
                        Hey Diego;
                        Jet Skiis, Personal water craft, what ever, are made to be very maneuverable. They would be a lot less fun if they were deep Vee's. One of those jet skiis in your photos is a modified V some place between a shallow and Deep V.
                        Viking
                        • Diegoboy
                          Administrator
                          • Mar 2007
                          • 7247
                          #72
                          True, but they both have the infamous "flat spot" on the hull.
                          • Diegoboy
                            Administrator
                            • Mar 2007
                            • 7247
                            #73
                            Here's the steering servo installed.
                              • 7277
                              #74
                              Still waiting to buy this thing..............................
                              • calcagno45
                                • Mar 2008
                                • 1006
                                #75
                                Im still waiting to see it go...
                                My prop hasn't been wet in a while.
