Pro Boat Formula Fastech Jet Drive Project
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    Originally posted by Meniscus View Post
    That's it? That's as far as you've made it?
    Speaking of driving, how come you depth perception is just fine to "eyeball" locations for various components for a boat, but as soon as there's a liquid surface, you claim you can't tell distance?
    (thinking that I don't want to ride with Diegoboy in a vehicle, let alone a boat)
    Project looks good
    I don't run a boat 2 feet from my face, otherwise I'd be great! We all would. The farther away, the greater the issue becomes.
    A classic example of my perception of depth. The tree in the water is clearly visible, My eye told me that my SV27 (Shock Therapy) was well behind the tree. My eye lied to me! Watch this...
    • Meniscus
      Refuse the box exists!
      • Jul 2008
      • 3222
      LOL, I've heard about this somewhere before.
      For the record, I understand. It was merely
      • Diegoboy
        Administrator
        • Mar 2007
        • 7247
        I know! No offense taken
        • Meniscus
          • Jul 2008
          • 3222
          I think you were lucky there weren't two targets on the lake, otherwise it would have sunk
          I do have to say though
          • Meniscus
            • Jul 2008
            • 3222
            • Rex R
              • 992
              you may find driving easier if you can gain some elevation, say for example a 3 foot stepladder, or the back of a pick-up truck.
              • Spot Me 2
                • Jul 2008
                • 769
                Yes, PLEASE put the mamba on the shelf for a while!! A 20 acre lake and you hit the only 2 foot thing in it.
                MMGMMarine
                RobertsonRacing
                • Meniscus
                  • Jul 2008
                  • 3222
                  Good call Rex Personally, I think he's been looking at the scale boats a little too much
                  • Meniscus
                    • Jul 2008
                    • 3222
                    (thinking we'll have to put training buoys in Loch Fembot to help hone his skills)
                    Hey, no new pictures? I thought you were working on this boat? Or is that just what you tell everyone else?
                    • Viking
                      • Jul 2008
                      • 133
                      Jets
                      Diegoboy;
                      I have a depth perception problem too, but I only see with one eye, which makes it really difficult. I seem to be having that problem with your boat. That hole looks to be too far from the transom. I have that same jet in an Electro Vee 29" and my intake starts 3 5/8" from the transom. Yours appears to me to be further than that. I'll add some photos. I ran a V drive with the motor over the shaft, you can see the motor mount in one of the photos, no motor in there. That kept the CG (center of gravity) in proportion. I don't see how you are going to mount a motor in front of that shaft and balance the boat. Unless you shorten the shaft a bunch. That is a 40mm impeller in that jet and it takes some HP to spin it. No short motors need apply.
                      The yellow tubing from the jet into the hull works great for cooling the motor and ESC.
                      Good Luck;
                      Viking
                      That Viking www.How2RC.com PULSO
                      Home made 36" DeepVee 50mph
                      • Diegoboy
                        Administrator
                        • Mar 2007
                        • 7247
                        Viking,
                        Thanks for the concern, Does this picture help? I measured your oic and used a known object to Gage the distance.( steering pivot point to transom) and it seems the same distance to me...
                        • Viking
                          • Jul 2008
                          • 133
                          Jets
                          Diegoboy;
                          Man I think you are in trouble.
                          Your ruler clearly shows the hole is 4 1/8" from the transom, that is the exact way I measured my boat and it measured 3 5/8"
                          The part of the jet that the impeller is in ( the jet chamber) has a flange that the nozzle is bolted to and that flange should be on the out side of the hull. that way you can seal the jet chamber to the hull, and get the nozzle off for maintenance.
                          Weeds and sticks get in there and around here acorns. The photo below clearly shows this. The chamber is inserted through the transom and into the intake duct. I sealed mine with 3M "5200" sealant.
                          Not a big deal you can fix anything in fiberglass.
                          Consider this the further back the intake is the more it stays in the water. there is no thrust when the jet is sucking air.
                          I have had the idea of an aluminum jet boat rattling around in my skull for a couple of years. My Electro Vee jet was great the ABS vacuum formed hull would give when it hit rocks in the stream. My Challanger twin jet Fiberglass hull is taking a beating. So much so I may pull the jets and do twin screws, counter rotating of course.
                          Sorry to be the bearer of bad tidings;
                          Viking
                          • Diegoboy
                            Administrator
                            • Mar 2007
                            • 7247
                            Viking,
                            I got it covered. Worry not my friend!
                            • ghostofpf1
                              • 392
                              Originally posted by ace028 View Post
                              Do you mean water rock crawling? lol
                              I think he means scale racing emulating full size river jet boat racing like this...
                              http://www.vidilife.com/video_play_1...River_Race.htm
                              Ghost
                              • Viking
                                • Jul 2008
                                • 133
                                Water rock crawling
                                I like it "Water Rock Crawling" here is the Electro Vee
                                and here is the Challanger twin jet. both are brushed motor driven.
                                ttp://www.youtube.com/watch?v=faWJTGbdM9Q
                                I don't know where the echo came from on the vid !?
                                Viking
