The Black Pearl P Sport Hydro 2017
  • bikepilot
    • Sep 2018
    • 22
    #376
    Yep! I'm planning on building one this winter. I think it will be a great runner! probable set it up to run limited. It'll be my first wood build for my first race season!! I'm excited!!!
    • robstercraws
      • Apr 2017
      • 151
      #377
      So by the looks of it the air bleed channel is widened and the sponsons has no step? Is that right?
      • NativePaul
        Greased Weasel
        • 2770
        #378
        I don't know what resolution you recorded it as Mike, but it is only uploaded to youtube as 480p, and shot vertically so only about 300 pixels wide, shooting horisontally helps quality as does uploading as higher resolutions.
        You can upload it with a even higher resolution than you actually shot, so if you record in 1080p you can upload it as a 4k video, it will still only be 1080p, but the 4k upload allows more bandwidth so it will compress the 1080p footage less and be better quality than if you just upload it as 1080.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2752
          #379
          That boat has a lot of history and its only 4yrs old. Jimmy had it for awhile, then traded it back to me for a later version! And.....it's SN001!!! So......let's see what you did to it Mike!!!!! Congrats on the record by the way.
          You got it. No step on the sponsons and bleeding more air. Those photos in post #367 are already obsolete. I cut a kit and it just didn't look right. The tunnel was way too narrow. I widened the tunnel but kept the same transom width. Looks much better now. Just about ready to cut it.
          I had no idea you could upload at higher res than it was shot. Reduces compression. Good to know!!
          • Shooter
            Team Mojo
            • Jun 2009
            • 2752
            #380
            OK, so here is the first spec boat. It is 31" long. Nothing glued, just fitted together. It was designed to fit the UL-1 hatch and nose with a piece of 3/4" round stock glued to the front. The airfoil is pretty aggressive on the leading edge.
            • Shooter
              Team Mojo
              • Jun 2009
              • 2752
              #381
              The bottom is far from traditional. A lot of air bleeding.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2752
                #382
                It's not the roomiest thing under the hood, but I guess it wasn't designed to be a luxury vehicle! It's the F1 class of FE!!
                I did manage to pack (2) 4S graphene 4000's, which are very long.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2752
                  #383
                  One more pic with the UL-1 cowl...
                  • betapro
                    • May 2017
                    • 16
                    #384
                    wow, nice design
                    • detox
                      • 2357
                      #385
                      I remember my mother watched Jack Lalanne on UHF channel 8.
                      • T.S.Davis
                        • 6266
                        #386
                        I'm not sharing my plans this time Pete. muhahahahaha
                        Noisy person
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2752
                          #387
                          what? Jack Lalanne??? and WHAAAAAAAAAAAT??? No sharing!!!!???
                          Been a few weeks. Not good ones. I'm still swamped with other priorities. I have (2) of the LSH kits cut.
                          • T.S.Davis
                            • 6266
                            #388
                            Pete, you coming to B's tomorrow?
                            Noisy person
                            • Mike W
                              • May 2018
                              • 348
                              #389
                              Just found this and am planning the same!
                              Otto RC Marine
                              • TRUCKPULL
                                • 3293
                                #390
                                Any one interested in a new cowl for there boat?
                                OK - made my first pull from this new mould.
                                It turned out very good.
                                This mould was made to fit the 20/40 Wiplash
                                I cut the cowl to fit in the Black Pearl - It fits perfectly (curvature on the front fits), There is enough room on the surface's of the cowl, to move the bubble forward 2" or to the rear 1 1/4" from where it is in the pictures.
                                I will start making some of these next week, MP me if interested.
                                Larry
