Outrigger transom bouncing - need help.
  • RiggerSpeed
    • Nov 2013
    • 12
    Predator outrigger: the rear end is bouncing and isn't stable. It's fine til you get to like 50-100% throttle then it starts bouncing.
    Need suggestions on what might be causing this.
    -COG off?
    -I've moved the battery backwards/rearward 5/8" to help load the rear.
    -P735 prop
  • TRUCKPULL
    • 3293
    What motor (size and KV) , batteries, hardware???
    We need more info.
    Larry
    • NativePaul
      Greased Weasel
      • 2770
      Shaft pointing downwards too much, and/or CoG too far forward, and/or too much prop lift, those P series props don't have that much lift but the more pitch you have the more lift comes with it, you could try cupping the blades and/or an X435 (I would say an X438 for a similar amp draw, but that means swapping to a 3/16 shaft, and lthe lower lift may give you more usable speed anyway (despite having less power available)).
      • RiggerSpeed
        • Nov 2013
        • 12
        My setup:
        3650, 3900kv 5mm shaft
        3S, 5000mah Gen Ace
        Seaking 120a
        Octura P735 prop
        • NativePaul
          Greased Weasel
          • 2770
          x435 will still give you good speed wit that gear when you get it dialed in.
          • boredom.is.me
            • Jun 2009
            • 626
            Why not an m series prop?
            Edit:
            I see why.
            • grsboats
              • 1011
              Too much lift with the 735..reduce to X435 with no strut mod to verify how your boat runs....basically your strut must be positioned to 0 degree.Gill
              GO FAST AND TURN RIGHT !
              www.grsboats.com.br
                At least part of the problem is the prop. It has less lift than the 1700 series it is based on, but still too much for a modern rigger. Where is the CG? That is the next thing to change, move it back 1/2" to 1" using balast if necessary. How fast do you want to go and how much run time?
                • coolcarwrench
                  • Feb 2015
                  • 22
                  Photos of you set up could help
