Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Hydromite setup - RcBoaters Forum
Hydromite setup
  • Dylan.g
    • 7
    Hydromite setup
    Hi
    What do you guys think about this setup for the hydromite.
    motor
    esc
    Thanks
    Dylan
  • Dr. Jet
    • 1759
    You will find that motor couplers are hard to come by in 3 mm bore. There are many similar (and sometimes even cheaper) motors that have either a 2.3 mm, 3.2 mm (1/8"), or 4 mm shaft. Couplers for this size motor are easier to come by.
    That motor should work well in a Hydromite. I've been using 3000 rpm/V outrunners on 2S in little hulls like the Hydromite and they work well with a 29 mm prop. I am about to try a 3850 rpm/V motor in my lastet micro hull.
    Try this one: http://cgi.ebay.com/RC-Model-3850-RP...713.m153.l1262
    I watched his auctions and picked up this exact motor PLUS a 30A ESC for about $25 shipped. If you are not in an immediate rush for a power system, it pays to wait for an opportunity to be an ebay sniper.
    A nation of sheep breeds a government of wolves
    • stablgr
      • Sep 2008
      • 96
      I got my 3000kv out runner and ESC from here:
      http://cgi.ebay.com/3000-Helicopter-...742.m153.l1262
      it was shipped all the way from Hong Kong to the USA in less than two weeks and for less than $25.
      I plan on using it in my hydromite when it finally gets built. It's getting there, but very very slowly!
      By the time a man realizes that maybe his father was right, he usually has a son who thinks he's wrong.
      • Dr. Jet
        • 1759
        This is a great deal and in fact, the "spec" motor for SSSH racing. It is a drop-in replacement for the 3850 Kv motor I mentioned above; or perhaps it would be better to say the motor above is a drop-in replacement for this motor.
        • Dylan.g
          • 7
          Its easier for me to buy of this site. Wot if i bought a coupler with a 2.3mm hole and drilled it out to 3mm.
          Thanks
          Dylan
          • Dr. Jet
            • 1759
            There are a couple of guys on this site that make couplers. Look for Jeff Wholt and/or Ned Schmidt (not 100% sure of the spelling). I think either one may be able to help you.
            Drilling never works well; the hole is never precise enough. I like to ream them to the final bore.
            • Dylan.g
              • 7
              I have access to a lathe at my school so i could always yous that.
              Dylan
              • Dr. Jet
                • 1759
                You'll need a lathe and a 3 mm reamer. That's not something I have scattered about my shop.
                • Dylan.g
                  • 7
                  Ill contact those guys you listed and see if they can make me one
                  Thanks
                  Dylan
                  • Dylan.g
                    • 7
                    What kind of li-po would you recomend for this setup.
                    Dylan
                    • Dr. Jet
                      • 1759
                      With the 3000 rpm/V motor, cells in the 1250~1500 mah range (20C) work well. With higher Kv motors like you mention, 1500~1900 mah (20C or more) would be my choice.
                      • Dylan.g
                        • 7
                        ok
                        Should it be a 2cell or a 3cell?
                        Dylan
                        • Dr. Jet
                          • 1759
                          2-Cell
                          • Dylan.g
                            • 7
                            Sweet thanks for the help
                            • jwv3
                              • Dec 2008
                              • 1
                              Dr. Jet,
                              Have you tried the 3850kv motor yet? I was wondering if the 30 amp mystery esc would still be okay with the higher kv motor (2s lipo) or if a larger esc would be needed.
