Forward Thinking Cyberstorm P-Ltd Mono
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Steve wanted something more substantial than his previous RtR mono which proved less than durable. I sent him an Insane34 P-Mono that ripped. Next, to compete with some forward thinking racers in a mythical kingdom where they dare to allow a wider selection of "spec" motors, this TP Powered P-Ltd Mono should get him on the podium
    First, a transom doubler of birch ply to reinforce the stock doubler apparantly made of Meunster cheese
    Big and strong Speedmaster stinger & dual pickup tapered rudder - before and after shortening stinger & raising/trimming rudder
    tapered tabs & nice racewater-ready turn fins
    [continued]
  • properchopper
    • 7708
    TP Power 3630 in CF mount supplemented by "mini-rails" providing much more bonding surface than with mount alone
    Leo cooling jacket just fits, comes with large fittings (and required mount to be notched)
    Birch ply battery platforms & ESC mounting thingie
    OSE Raider 150A ESC - tucks right in & lots'a bang for the buck
    [continued]
    • properchopper
      • 7708
      Boat will run 4S2P so integral parallel adapters permanently soldered on ESC
      predetermined layout + long battery trays allow CG tuning . Trial balancing worked out using Super Hi-Tech CG-O-Meter thumbup1:
      [continued]
      • properchopper
        • 7708
        Steve has some cool graphics planned to finish off the hull and should kick some on the racecourse with this Forward Thinking Cyberstorm
        Tony
        rcboatbuild@hotmail.com
        • Darin Jordan
          • 9446
          Tony, in case on one has told you lately... you ROCK!
          Love ya, Bro!! See you in November??
          Darin E. Jordan - Renton, WA
          • properchopper
            • 7708
            Yowzah !!
              Very nice Tony. Love the color too of course!
              • Tails Up
                • May 2016
                • 51
                Nice work!
                • 785boats
                  Wet Track Racing
                  • 3423
                  Beautiful set up.
                    Very clean, very pro as always. Glad to sub your thread.
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      Plan on setting up my next mono exactly the same, clean as always sir!
                      NEVER SATISFIED RACING
                      Fine Design 32 V-Hull 4082+6s
                      • Mxkid261
                        • Jun 2015
                        • 734
                        Looks great. Think I will have to get that rudder for my DF 29. What does cutting the blade shorter help achieve? Also, what setback is that bracket? Thanks
                          Less rudder = more speed.
                          • properchopper
                            • 7708
                            Ray's correct. Plus, the longer the rudder, the more effect it has on the running attitude (as in pulling the nose down).
                            The Speedmaster rudder I used for the Cyberstorm is likely to end up being too large for the DF 29. It's huge, heavy and designed for much larger nitro or gasser hulls. Not only is it long, but quite thick. To shorten it's penetration I not only trimmed the bottom shorter, but modded the upper mounting location by cutting some of the top of the blade away and re-drilling the bolt holes to raise it up :
                            stock blade mounting location:
                            raised mounting location:
                            • Mxkid261
                              • Jun 2015
                              • 734
                              I does look quite thick now that you mention it. I was planning on using the speedmaster 21 rudder but I wish they had a dual pickup version
