Pursuit mono floodchamber build, first
  • NativePaul
    Greased Weasel
    • 2764
    #31
    I hate coremat, it is cheap and easy to use as it is an even thickness and drapes over 3 dimensional curves pretty well, but it provides no strength in itself, it just soaks up resin like a sponge and the resin provides the strength, you'd get just as good strength to weight if you built up the thickness with toilet paper.
    However it does do its job as a core in spacing 2 surfaces apart to stiffen the composite, and it is hard to get it off so if you have it in already you may as well put it to use by glassing over it. No need to use a lighter or stronger core as well, you already have the weight and strength limitation there, adding extra core will do little for you.
    • wakenshake
      • Dec 2012
      • 22
      #32
      Ok so since it already has core mat no sense of putting more filler in. So just put couple layers of glass in. This is easier and will look better when i cut out fc hole as there wont be half wood and gray epoxy exposed.
