Well the kit went together as easily as any of Mikes other kits. Just follow the numbers, letters, & dotted lines.
The simple dry fit, & wick some medium CA along the joins makes it quick & easy. Just need to make sure everything is true & square as you go.
After assembling the basic box for the tub I glued all the 1/8" stringers in the corners.
Then added the hatch liners to the underside of the deck & glued that on.
The frames for the rear sponsons were added, & the transom doubler was Epoxied onto the transom.
I added some bits of foam into the rear sponsons & glued on the skins & sanded everything to shape.
The only thing I added was a 1/4" ply doubler to the sides of the tub where the boom tube exits the hull. Just for a bit of extra strength. I'm good at hitting buoys with boats.
