OSE BlackJack Conversion
  • Steven Vaccaro
    Administrator
    • 8934
    After a disastrous bench test with the stock drive I quickly found out that the universal will not take the power of bl or nitro.
    I wanted to keep the scale looks of the steerable outdrive. Here's what I have done.
    I removed the stock prop shaft.
    Removed the stock bushings.
    Drilled the stock out drive out to 1/4" or .250
    Made a sleeve out of 1/4" k&S
    Slide in a Stinger sleeve bearing, than cut it to the shorter length to fit the BJack.
    Ran a new .150 cable with 3/16" prop shaft all the way to the new outdrive.
    The new system is as smooth as butter!
    I fired up a stock sv and a the sv powered Black Jack next to each other. The BJ is remarkably quieter than the sv. I hope to water test today! Pictures to follow in a couple of minutes.
    Steven Vaccaro
  • SJFE
    • 4867
    Good Luck man!! I was hoping some one would try to improvre on the stock system. Do you have any ideas for a uiniversal upgrade? I had thought of modifieing a nitro or electric stadium truck mip cvd joint.
    • Steven Vaccaro
      Administrator
      • 8934
      Well I'm sure you could find some better universal but matting it to a flex will be no easy task. I have not water tested yet, but I can not see a downside to the outdrive mod. I cant wait to try it.
      My mod will less than $20 !!!
      .150 cable and shaft is $11
      bushing is about $6.
      1/4 k&s is about $2.
      Of course this doesn't include the tools. But those I consider investments.
      Steven Vaccaro
      • SJFE
        • 4867
        Oh ok now I get it. I was thinking somthing completly diffrent. Dude I wish I would have thought of that. Would have prolly saved me a ton of time and money finding a S&R setup that works. But I guess it a good thing I did the research. I hope to see some video:). Hey um I am assuming your keppin the radio box hu?
        • avengersteve
          • 395
          im going to be trying the same set up.. thanks for the pics... what are you using for the motor mount?
          restoring the collection
          • Steven Vaccaro
            Administrator
            • 8934
            Radio box is staying. The mount is something I made. I need a new cad guy to draw it up for me.
            Steven Vaccaro
            • SJFE
              • 4867
              Where you thnking of using the engine lugs like this boat. Or did you have a tunnel mount in mind?
              • Tunda
                Eh no steal my slipa
                • 844
                blackjack
                steven did you run it yet?:D
                Hawaiian Tunda
                • rcBPman
                  • 7
                  Steve.....send me some dimensions of that hull and mount you made or just give me a call and i can get it drawn in a few mins. All views and Isometric...3D CAD is on its way....my company is getting it very soon!!!
                  -Greg-
                  SSI Racing
                  • Steven Vaccaro
                    Administrator
                    • 8934
                    greg thanks for the offer. I will take it out and draw it when I get some time. Will you be in NH this weekend?
                    Steven Vaccaro
                    • Tunda
                      • 844
                      steven its been awhile did you run it yet let us know whats up.............ALOHA.....:D
                      Hawaiian Tunda
                      • Steven Vaccaro
                        Administrator
                        • 8934
                        Nothing new, I have not run it since the last time.
                        Steven Vaccaro
                        • ISR
                          • Dec 2007
                          • 7
                          Prop
                          I have a Blackjack Brushless that I ditched the universal and went with 3/16" flex shaft and 3/16" prop shaft. This looks to be a very good idea.
                          My problem is the prop to use. The prop that came with the boat for the smaller prop shaft is 1.6"x2.5" and 3/8" wide. I got a Graupner k series 54mm grp 2317.45 that is 1.77x2.48 that fits a 3/16" shaft. and it's is way too large when there is only 1/64" different. it's also 5/8" wide, thats 1/8" wider than the prop that came with the boat.
                          This prop is only 1/16" away from the water intake tube. That 1/64" differance to more like 1/8".
                          WHAT AREN'T I NOT SEEING HERE AND WHAT SIZE PROP DO I NEED.
                          Thanks
                          ISR
                          • Rex R
                            • 1007
                            try a k-42 or an x642(sharpend and balanced octura)
                            • TRUNKMUNKY
                              • 61
                              Won't this not turn?
