Johnny's HK Flowmaster
  • grsboats
    • 1011
    #31
    https://www.youtube.com/watch?v=zAIY...Y0I5GGw4...too much funny.......but do not use it in your boats if they are not bulletproof versions.Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • Prodrvr
      • Jul 2015
      • 701
      #32
      This is all making me want to just scrap the idea of fixing up this boat. Maybe I should just get a good hull to start with.
      • Beaux
        • Dec 2015
        • 550
        #33
        Man , that hull has some nice lines they all need a little luv be it brand new or used.
        • Prodrvr
          • Jul 2015
          • 701
          #34
          Well, I'm going to do the foam today and see what happens. There may be a 51" Victory cat from Central RC Marine in my future.
          • Beaux
            • Dec 2015
            • 550
            #35
            Let us know, good luck!!
            • arrover
              • May 2015
              • 322
              #36
              Why are you so dead set to use the foam when multiple people have told you it's a bad idea? One guy even had a bad foam experience with the same hull. The first time I was running my Flowmaster I brought it in and picked it up by the front of the tunnel and the paint/gelcoat cracked just from that light hand pressure causing the front deck to flex. It's really thin in that area and it seems like you're just inviting trouble by trying the foam. In the end it's your boat but I tend to listen to people who have done a project more than I have. If you're worried about the look of pool noodle floatation you could try water pipe insulation from the hardware store. It's black/dark grey.
              ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
              • Prodrvr
                • Jul 2015
                • 701
                #37
                Well, the foam is done...and it came out great. Yes, if you tilt it in the light just right, there are two very small dimples in the deck. This is because I didn't run enough tape across the hull. Otherwise everything is good. My temp gun is at the girlfriend's house, so I couldn't get an exact temp on the curing process. Going by feel...an electric blanket turned all the way up when it's under a comforter...not hot at all. You squeeze the hull now and it's like a rock! I poured a total of 10.2 oz. of foam in five stages. The rest of the interior is all cleaned up and ready for reinforcement.
                • Beaux
                  • Dec 2015
                  • 550
                  #38
                  The paint and clear look way better than the average flowmaster. The boat looks good, the foam really doe make it stronger. Nice.
                  • Prodrvr
                    • Jul 2015
                    • 701
                    #39
                    The front of the hull is SOLID!! Almost like you would have to smash it with a hammer to do anything. I really wished that I weighed the hull before adding the foam. The hull now weighs 2lb.1oz.
                    • grsboats
                      • 1011
                      #40
                      The big problem with two part foam is that is continue to expand very slowly with hot temperatures...I'm cheering for you and let's see how it turns in a few months.....
                      www.grsboats.com.br
                      • Prodrvr
                        • Jul 2015
                        • 701
                        #41
                        Let's hope it keeps expanding toward the back of the hull lol. Have some cf sheet, fabric, and epoxy on the way. I'll probably do the transom and floor reinforcement next weekend if the stuff shows up next week.
                        • TheShaddix
                          • Sep 2013
                          • 759
                          #42
                          Glad it turned out well. But yeah, over time the foam will just keep breathing. As for the weight, don't be concerned. On a cat the more weight you have the better (up to a point). Otherwise it won't stay on water. When you add the motors, esc's, and lipos, whatever weight the hull had would be nothing in comparison!
                          • Prodrvr
                            • Jul 2015
                            • 701
                            #43
                            Thanks! Yeah, it should balance out fine by the time everything is in it. Was thinking when the time comes, to try a pair of ss 4017 5 blade cleaver props from Prop Shop.
                            • TheShaddix
                              • Sep 2013
                              • 759
                              #44
                              5 blade? You lose all the torque when you run more than 2 blades. If your objective is acceleration and speed, stick with 2 blades.
                              • Prodrvr
                                • Jul 2015
                                • 701
                                #45
                                Top speed. Acceleration I could care less about. So a 42mm 2 blade?
