Time for a Mean Machine
  • Beaux
    • Dec 2015
    • 550
    After reading for months on all kinds of boats, motors and esc's . It looked like I would spend four to six hundred dollars on a rtr and still have to modify it carbon fiber floor transom all the seems and so on. I've read up on the mean machine, tough boat and I like cats. I have a couple F1 boat , i like the way they fly and for the money the MM2 was the way to go So here is my build not high dollar but dependable.You will even notice an outboard on it ,I could not wait on my parts so i pulled it off my F1 to play it ran very good. Ina couple of months I think I'll build a twin.
  • Beaux
    • Dec 2015
    • 550
    Some of the parts i had I made the servo mount out of a piece a stainless steel. I had a couple 3674 motors one 2250 kv and one 3100 kv. I'm going to start with the 2250 on 5s and a m 445 prop. I used a .187 cable drive , an OSE raider 6s 150 amp esc, speedmaster sport strut, flex cable saver which paid for it self first time out, OSE- alum. rudder w/pick up, K&S brass tubing Du-bro safety locks,and Aeromarine coupler.
    • Beaux
      • Dec 2015
      • 550
      Here Is the esc, motor and futaba servo.IMG_0262.JPGIMG_0263.JPGIMG_0264.JPGIMG_0265.JPG
      • Beaux
        • Dec 2015
        • 550
        And the finished product.
        • Beaux
          • Dec 2015
          • 550
          Here is a picture of the F1 donor boat for the outboard.
            Nice. It looks orange in some photos and red in others.
            • Beaux
              • Dec 2015
              • 550
              Thanks. Had a different light on.
              • Tamelesstgr
                • Jun 2014
                • 1512
                How do you like that OSE raider 6s 150 amp esc?
                NEVER SATISFIED RACING
                Fine Design 32 V-Hull 4082+6s
                • Beaux
                  • Dec 2015
                  • 550
                  So far it seems to be fine. I set it up with the program card. Do you run one any problems?
                  • Tamelesstgr
                    • Jun 2014
                    • 1512
                    I don't, but been wanting to try them next time I am in need of one.
                    • Beaux
                      • Dec 2015
                      • 550
                      As soon as I said no problems, the next time out it went up in smoke. On 3s just learning how to drive the boat very little wide open time. Talked to Steven he said send it back, man I just can't say enough good things about those guys.
                      I just got a barbwire xl for my grandson have you had any problems with yours? thanks.
                      • Blandon
                        • Mar 2016
                        • 51
                        Mean Machine looks great!!! I've had quite a few Aeromarine hulls over the years and never had any issues, some of the strongest hulls out there IMO. I still run a 50" Apache I've had for 13 years. Good luck with the new ride.
                        • Beaux
                          • Dec 2015
                          • 550
                          Thanks I really like it.
                          • JMSCARD
                            • Mar 2010
                            • 4174
                            5s 2250kv with that boat and that 45mm prop is to hotness setup for 5w btw... If set up nice you may land on a x442 prop .... I've done a lot of 5s setups in those mean machines and 5s 2250kv is a hot setup and definitely to hot for a 36mm can size motor... your pulling some amps for sure .. a 2200kv mamba monster with 5s in my Mean machines setup on ragged edge with x442 would get things pretty warm even the t180... 130-140 temp ish...which is about as hot as you should go :)
                            • Beaux
                              • Dec 2015
                              • 550
                              Yes sir, I agree I ran it once like that and it was just crazy. So i went down to 3s 11.1x2p. The 36 can is all I've got right now. Next month I'll do a 4074 leopard. Just learning how to drive it now , I think I'm gonna need a bigger pond.
                              Do you think the 3s will work on the 4074 or would 4s be better?
