What is the preferred method of joining a prop shaft to a flex cable - soldering it or using epoxy/loctite ?
Prop shaft to flex cable - solder vs epoxy/loctite
I've only used solder so far, but this http://forums.offshoreelectrics.com/...-using-Loctite might be helpful.
Both work fine if done right, I have done way more silver solder in the over the years, but only use Loctite now, it is easier and there is no risk of softening your shaft/stub. I have never had a joint I have done with either method fail, in my experience the joint is stronger than the flex or wire and it will break elsewhere. I have never heard of anyone using epoxy, I use Loctite 603 at home which is nice and thin for ease of use but takes a long time to reach full strength, and carry 638 in my field bag, which is much thicker and can be a PITA to use with hydraulicing, but will set between heats if you snap a shaft.Paul Upton-Taylor, Greased Weasel Racing.
How do you get a 3/16 OD flex cable into a 3/16 OD shaft? If by milling it sown, how do you do that?
I have heard that you cut the outer winding off with a dremmel then solder the inner into a .150 hole, (silver solder not loctite as the outer later only has a butt joint with very little surface area, I can't say I have ever done it, it looks like a bad idea to me, if I want to throw more power at something than .150 will handle I will use a wire.Paul Upton-Taylor, Greased Weasel Racing.
I find the best way is to buy them already assembled.
http://www.offshoreelectrics.com/pro...?prod=ose-1190
But then again, I'm getting lazy in my old age.See the danger. THEN DO IT ANYWAY!!!
Yeah. I wish Steve had an auto shipment function. Seems like I need one every month or so.Originally posted by 785boats View PostI find the best way is to buy them already assembled.
You shouldn't be getting through flexies that quickly. Do you have a bend rather than a curve in your stuffing tube, or a misalignemt at one end? Are you either running teflon or greasing it before every run? Are you removing the flex drying it and oiling it after your day's running?Paul Upton-Taylor, Greased Weasel Racing.
