Blandon's P-Limited tunnel build
  • Blandon
    • Mar 2016
    • 51
    I have a Grimracer 42x55 2 blade in there now. I will see what that does first and go from there. I also have an Octura 445 2 blade that I think will be a good prop for this hull.
    • Beaux
      • Dec 2015
      • 550
      I saw that, looked like something extra. I'm running a K&B leg w/leo 3650 mm 2930 kv haven't been able to open it yet.
      • Blandon
        • Mar 2016
        • 51
        2930 KV is a lot of motor. That thing will haul ass!!! What are you running for an esc and battery?
        • Beaux
          • Dec 2015
          • 550
          A hobbyking 90 Amp 5s 18.5 volt. She wants to fly after about 50ish.
          • Beaux
            • Dec 2015
            • 550
            I should probably turn the voltage down, I don't think the esc will hold once i get it to where i can stand on longer. AS long as i stay with a 40 mm prop it does'n get even warm.
            • Blandon
              • Mar 2016
              • 51
              I forgot to ask, what hull are you running?
              • Beaux
                • Dec 2015
                • 550
                a f1 hornet from hk, and i've got acouple generic chinese. I put a couple layers of resin on the bottom of the sponsons to sharpen up the edges, I guess blue printing it really helped in the turns.
                • Beaux
                  • Dec 2015
                  • 550
                  How long is your boat, i'm looking ata31.5 inch fiber glass for about a hundred bucks the same place i got the 24 inch chinas very well built and solid.I may have to step up for this motor.
                  • Blandon
                    • Mar 2016
                    • 51
                    The VS-1 hull is 28" long
                    • Doug Smock
                      • 5264
                      Looking good so far Blandon.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Beaux
                        • Dec 2015
                        • 550
                        thanks.
                        • Blandon
                          • Mar 2016
                          • 51
                          Thank you sir!!!
                          • iridebikes247
                            • 1528
                            Nice this looks great so far, took guts sawing into the hull lol
                            • Blandon
                              • Mar 2016
                              • 51
                              Thanks, yeah I basically opened the box, took the hull out and started sawing!!Lol
                              • Beaux
                                • Dec 2015
                                • 550
                                Blandon, are you planning on painting or leaving the hull natural?
