how to install decals
  • Crash
    • Oct 2015
    • 313
    hello men'
    I have a set of decals to install on my boat.
    never done it before.
    what is the best method?
    thanks guys
    Dan
  • iop65
    • Mar 2013
    • 367
    this is the way i do it :
    some water with a little soap i it
    apply that on the hull and a little on the decal with soft sloth ( no need for foam)
    put the decal on the hull , you can slide the decal around on the wet surface
    when decal is in the right position :take a dry cloth and push the soapy water that is between the hull and decal to the edges
    it takes a while to get away all the water , best way is to start in the middle and try to get the water and air that is trapped to the edges
    when all the water is removed the decal will stick to the hull without losing it's ability to "glue" ( sorry for my english)
    be sure to get all the water/soap from inderneath the decal , like i wrote this will take some effort
    • Crash
      • Oct 2015
      • 313
      thank you
      • monojeff
        • Nov 2010
        • 2728
        Not all decals are created equal.
        What type of sticker is it?
        What size and where are you applying it?
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • Crash
          • Oct 2015
          • 313
          factory proboat
          applying to boat hull
