Black pearl
  • TRUCKPULL
    • 2971
    Black pearl
    This is a set of pictures that I took while building this Kit that I got from Pete
    I am sorry that I did not get any pic's of the frame by itself.
    This kit went together very easily.
    In this build I only used CA to tack the frame together.
    Everything else is glued with EPOXY
    Pic. #1 - Turn Fin bracket with extra mount rod
    Pic. #2 - Blind nuts with an extra 1/8" ply inside the Sponson
    Pic. #3 - Pink foam cut to fit and glued in
    Larry
  • TRUCKPULL
    • 2971
    Pic. #1 - Sponson foam glued in
    Pic. #2 - Foam all sanded
    Pic. #3 -Sponson sides sanded
    Larry
    • TRUCKPULL
      • 2971
      Pic. #1 - Sponson sides installed
      Pic. #2 - First step in sanding and shaping the sponson bottoms. Take a reading across the bottom of the hull, and set your level to zero.
      Pic. #3 - Right sponson as seen from the bottom
      Sanded flat to 0.0 degrees, you must check the entire length, as well as the recovery pad.
      Larry
      • TRUCKPULL
        • 2971
        Pic. #1 - I set the Left sponson at 1.9 degrees and check it all the way forward to the tip of the sponson
        Pic. #2 - Now set your level lengthwise on the bottom and reset to 0.0 degrees
        Pic. #3 - Now you can check your angle of attack, and make sure that they are both the same.
        Larry
        • TRUCKPULL
          • 2971
          Pic. #1 - Sponson recovery pads installed
          Pic. #2 - I use 1/16" G-10 fiberglass plate for my ride pads. - Sponson ride pads installed.
          Pic. #3 -Installing the decking - lots of weight and clamps to keep everything flat and tight.
          Larry
          • TRUCKPULL
            • 2971
            Pic. #1 - Fitting of the deck and nose piece - I used a pair of Lexan scissors - they seemed to work pretty good.
            Pic. #2 -Another angle - Nose is now finished.
            Larry
            • TRUCKPULL
              • 2971
              Pic. #1 - Interior got some fiberglass cloth and epoxy reinforcing. Motor plate got four extra holes to add air cooling along with the aluminum water pipe install for the ESC and Motor.
              Pic. #2 - Another angle
              Larry
              • 785boats
                Wet Track Racing
                • 3169
                Looks great Larry.
                Don't you just love the balancing act with the weights & clamps. I love seeing what different people use for weights.
                • TRUCKPULL
                  • 2971
                  The rough looking gray blocks are 1" thick pieces of Lead, they weigh about 13lb. each
                  Larry
                    Wow! Looking good! Great craftsmanship there! I wish I had the patience to build something like this.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      Can't even express how fulfilling it is to see people building this thing. Nice job. I really like your wariness to the ride pad aoa and dihedral angles.
                      • T.S.Davis
                        • 6228
                        Larry, throw some glass on the inside of that nose piece. Then maybe some 2 part poly foam.
                        I've seen and raced against Pete's a number of times. You'll love the way this runs Larry. Kinda reminds me of those mini Whips you were building the way it runs.
                        Noisy person
                        • TRUCKPULL
                          • 2971
                          Pete
                          We will see if my wariness and my small sponson modifications pay off when I get it wet and setup(sometime in May or April)
                          Larry
                          • Doug Smock
                            • 5264
                            Nice work Larry!
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • TRUCKPULL
                              • 2971
                              Originally posted by Doug Smock View Post
                              Nice work Larry!
                              Thank You
                              Doug
                              I hope it will be as fast as some of your boats.
                              Larry
