8s1p by 2-4s in series.
MHZ Racemaster ~SINISTER~
I have Apophis to thank for that. I've never done one, so I took it to Shawn for a lesson from a proOriginally posted by dasboata View PostLooks great the inlay came out really nice !!! that's not easy to do nice and dry like that !
I just picked up a DF sniper I'll be attempting my first inlay on that when I get around to building it.
Michigan Fast Electric SAW Club
Got a little more work done today. i ordered an esc mount from MBP but needed a CF plate to be able to mount it, I don't have any laying around that's big enough so I decided to use a old CF battery tray. Looks like it will work well
I also got the rudder mounted and water inlet installed.
That's one intimidating looking mono
Had some unexpected time today to mess around with the mono. I got the steering linkage installed, I'm using a carbon fiber rod so I need to get the servo arm aligned perfectly. Also got the water outlet and antenna mount installed.. I got the hatch bolts installed tonight as well
Next weekend I'll be working on getting the servo mounted just gotta figure out how lolMichigan Fast Electric SAW Club
Using a carbon fiber steering rod obviously cannot be bent, and I didn't want to put a shelf in and cover up easy access to the transom hardware. I found a servo arm from an airplane website that is perfect length so I can still use the mount I have, and get perfect alignment with the linkage
I'll be getting the servo mounted permanently tonight.
Attached FilesMichigan Fast Electric SAW Club
Excellent servo choice. My Radiopost servo is fantastic. Great looking build!Originally posted by gixx1k2 View PostUsing a carbon fiber steering rod obviously cannot be bent, and I didn't want to put a shelf in and cover up easy access to the transom hardware. I found a servo arm from an airplane website that is perfect length so I can still use the mount I have, and get perfect alignment with the linkage
I'll be getting the servo mounted permanently tonight.37" Fightercat Shocker powered by Neu 1530 on 10S
Nice job again. That stuffing tube mount is sick too the maiden is going to be a real experience.
Can't wait for the ice to meltOriginally posted by iridebikes247 View PostNice job again. That stuffing tube mount is sick too the maiden is going to be a real experience.
the maiden should be interesting, I'm worried there will be to much torque roll with how narrow this hull is. May have to shim the drive a little
Went to my buddy's to pick up the boat today
now just need to reassemble her
Hi, I read at the start of the post that you would be getting your hardware done in black. I to go with that colour and it comes up great. The only thing I wanted to let you now was that with the trim tabs you have from speed master I could not get the stainless hinge pin out?.
I tried heating it, drilling it and hammering it. Not sure how they assemble them but it seems they must have a thread machined on one end and then the screw head must wind off during manufacturing.
Has anyone else tried to pull them appart successfully?.
Thanks Shane.
