submerged to surface drive conversion
    ...I used the turn fin holes location from the previous setup. Are they fine at the angle they're at or do they need to be vertical
    The fins should be at right angles to the hull bottom surfaces. In their current orientations they will likely not work very well.
    • cmoo
      • Oct 2015
      • 71
      A couple of pics from last week. Only have to silicon all the hardware, mount the aluminum battery trays and do all the wiring. And some final touches. The last 20% of the build always takes the longest.
      • Beaux
        • Dec 2015
        • 550
        Looks good, I like the color.
        • FlogginHarvey
          • Mar 2016
          • 25
          How did it go?
          • cmoo
            • Oct 2015
            • 71
            Originally posted by FlogginHarvey View Post
            How did it go?
            Video Quality isn't that great. Almost obliterated it into the wall of the pond haha. Would have been a bad day. But it planed out nicely after some adjustment and it definitely has some speed probably too much for me, Definitely a big boat haha
            • FlogginHarvey
              • Mar 2016
              • 25
              That thing ran sweet! Noce work and thanks for posting the video!!! Turning off power is not ideal - as mentioned by the voice on the video. Too funny...thank goodness it was a close call and not a thunk.
              I saw a post about the turn fins above. After seeing your quick video I might make the same suggestion on the placement/angle, not to be pushy or rude. Reference once of my 48" gas monos as a quick example. Hull is a little different dead rise and strake layout but the overall principle is the same.
              You more or less want the turn fins perpendicular to the hull running surface so the lower one would be pointed (more or less) vertically straight down in a hard corner...the first pic below is probably best example. Both boats are SpeedMaster hardware very similar to what you have.
              Dumas Scarab 38KV Gas:
              And a Rico Offshore Classic:
              • cmoo
                • Oct 2015
                • 71
                another running video. any tuning suggestions based upon the video are welcome.
                and to flogginharvey, thanks for the tip, i have them verticle currently, so if the boats on the stand, theyre perpendicular to the ground.
                • cmoo
                  • Oct 2015
                  • 71
                  Pic of all the internals for anyone that was wondering.
                  And I pic of them
                  Before I did any research and knew nothing what so ever about FE boats
                  • cmoo
                    • Oct 2015
                    • 71
                    thanks Beaux!! probably why i bought it in the first place haha
                    • Beaux
                      • Dec 2015
                      • 550
                      Wow that boat was movin, nice rooster.
                      • cmoo
                        • Oct 2015
                        • 71
                        Voice in the video was my over dramatic little brother not me haha
                        • cmoo
                          • Oct 2015
                          • 71
                          Couple of pics after her first run
                          • cmoo
                            • Oct 2015
                            • 71
                            Another running video, after about 5 minutes of running at mostly full throttle the temps are around 95-98 Fahrenheit. Moved the packs back a couple inches and it's running right where I'd like it. A little chop in the turns but I think that has to do with my turn fun placement.
                            Currently running the octura x457 but id like to prop up if possible, any prop recommendation or how much bigger I can go while still staying in a safe limit of my capacity? Thanks.
