That should work, did you back it with cloth?
Carbon shocker build
I am adding a couple more layers to the underside. The way I fit that was I grinded a square recess and then sanded the carbon plate a little thinner and to match the curve of the hatch. Then roughed both surfaces up a lot and even put some little divots for the epoxy to grab. Taped it up and let epoxy flow into the recesses. I had to fill a few little pin holes last night. Tonight I'll sand again and then add two more layers of glass to the underside (inlay) and add some more carbon cloth around the perimeter for more strength.Originally posted by srislash View PostThat should work, did you back it with cloth?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Yes it's water based. I'm not sure just yet if I'm painting the whole thing again. I probably should. Here it is after sanding flat and a few coats of primer.Originally posted by Beaux View Postis that the water base green it looks like it feather edges ok, im gonna try some on this f1 i need to repaint. later.
In a lake about 40ft deep where it's at.Originally posted by Beaux View Postthe boat you sank , was it in a river or a pond? i lost a chopper in a pond and recovered it with a cast net.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Thx. Once it's painted you won't be able to tell. I think I'll just repaint the whole thing.Originally posted by Beaux View PostWOW, your repair came out nice! Yea that might be a little deep for the net idea.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
That's a cheetah I'm finishing up. I epoxy carbon plate to the underside of the rails for the threaded inserts I rivet in place for the hatch bolts.Originally posted by Beaux View Postwhat do you have all taped and clamped in the back ground? got my out board together on 18.5 volt haven't run it yet but i'm fixing to go to the boat launch.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
After close inspection, I did find where the seam cracked, about 7" long. Not sure how or why because there's carbon inlay there and I couldn't get it to open up. It was in a section that the hull halves weren't lined up well anyway (ever had a shocker then you know they aren't the cleanest or nicest assembled hulls). Anyway, I sanded it down some and cleared a trench in the crack. Then put some west systems over it.
Here's after epoxy. You won't even be able to tell when I'm done.
And I've made major progress on the hatch. I don't have a picture the last coat (had to leave and bring my son to the e.r. Because he fell off one of those stupid hover boards and hit his head badly) but the repair came out awesome. You can't even tell it was ever broke.
I layed a layer of Kevlar just for added insurance.
Here's the first coat. Speeding up the drying time in my powder coat oven on low heat.
