Aeromarine 44" hydro
  • AntronX
    • 361
    #106
    Sorry, UB. I messed up with the codec and got 1086 MB file after 1 hour of rendering. I am trying again, but now it is expected to be online by 3 am.
    • Ub Hauled
      • 3051
      #107
      still... 12a is a good time for me at least....
      • AntronX
        • 361
        #108
        new video!
        Youtube: http://www.youtube.com/watch?v=lQjEvDyicUo
        Vimeo: http://vimeo.com/6426708 (can download original source video in very high quality)
        Did the forum go down for anyone else last night at around 2 AM eastern?
        • bustitup
          • 3072
          #109
          nice vids......I have that same motor I want to use in a 41" sprint
          ya OSE had a bad connection I got frustrated with last night
          • AntronX
            • 361
            #110
            Bad day today. 2215 burned up. Not sure why. Controller is fine.
            • Ub Hauled
              • 3051
              #111
              Anton, that's a great video.... nice handling on her... why do you run w/o a cowl?
              Another thing, lipos are best when at 120F their resistance drops considerably, so make sure that
              it does not get too cold.
              Now, sorry about the motor... What where you doing?! Running normally and then just "pooof" ?
              • AntronX
                • 361
                #112
                I ran without it because it's a pain to mount and I have taped down all openings. Good point on battery temperature, will try to regulate cooling somehow to keep them close to 120F.
                Now, full story on motor incident. Ran the boat around the race course, maybe 7 laps. Aimed to run it until voltage cutoff would signal that battery is discharged. So, the controller started throttling down and I turned around and headed for the shore. Then within 2 seconds all power was lost, motor did not spin at all. That was strange, usually I can still drive for a awhile at low speed. When I got the boat and peeled off the lid, immediately the smell of winding lacquer poured out with some hints of water vapor that looked like smoke at first. Smell of lacquer did not smell burned. I touched the motor and it was very hot to the touch, could not hold it. Water cooling was NOT clogged. I watched outlet nozzles during the run. Something was very wrong that could cause the motor to get that hot with functional water cooling that kept motor at 105F day before. Looking at copper windings through back ventilation holes I noticed a single strand of wire that was darker than the rest. I did not run data logger that time, so no data on amp draw. I did notice slower speed at the beginning of the run, but no GPS data either. It just seemed a little bit slower to me today. Flex shaft was greased and grease was thinned with light mineral oil as usual. I spun the prop by hand, as I do after every time I grease the shaft. Did not feel stiff at all, felt as usual.
                • AntronX
                  • 361
                  #113
                  Also, the controller does not want to arm anymore with that motor. It did arm once and I gave it little throttle. Motor tried to spin but stuttered badly. I guess this indicates partially shorted phase, that does not have any back EMF for controller to estimate proper rotor position. Controller spins my old 2230 just fine.
                    • 9481
                    #114
                    Dang sounds like the very same thing that happend to me yesterday with my MM running a 8XL.. motor looks fine but does the same thing as yours
                    • Ub Hauled
                      • 3051
                      #115
                      what's the voltage for the cutoff?
                      It never overheated?
                      That sounds like a burned motor to me unfortunately.
                      • AntronX
                        • 361
                        #116
                        Cutoff is around 3.125V per cell or 25V total.
                        What overheated? Controller? It was normal temp. to the touch, same as every other run before. LiPos were the same.
                        Looks like burned motor to me as well. Just hooked it up to my old Hydra 120 on 5S. Hydra did arm with it, but quickly gave up trying to spin it as well.
                        • AntronX
                          • 361
                          #117
                          The question remains on why did it get so hot and why is there a shorted strand in the stator. Could it be shot lacquer insulation? Lacquer that is poor quality or applied to thin? I will be calling Mr. Neu on Tuesday.
                          • Ub Hauled
                            • 3051
                            #118
                            Laquer melts under heat... extreme heat. like a short or over powering the motor.
                            How about the screws? Are they cut or is there a chance you
                            accidentally could have touched the wires w/ them?
                            • AntronX
                              • 361
                              #119
                              accidentally touched the wires?
                              Screws are cut and it's impossible to touch wires with them due to turbo fan being in the way. I am not ruling out motor being over powered, maybe due to incorrect timing setting? This controller is set on auto timing. It did not want to arm set in neutral. So I measured amps and left it in auto. I don't have programming software or USB adapter for this Schulze. I ran it pretty much straight out of the box.
                              • Blueprint
                                • 13
                                #120
                                Hi Anton, Did you run your normal prop?
