Delta Force mini Build questions
  • Mikey P.
    • Sep 2008
    • 48
    I looked into using mini cat usa hardware but it requires a 3mm prop. Are there any other options for running hardware for this boat that will use a standard size prop?
  • Steven Vaccaro
    Administrator
    • 8724
    You can also use a 1/8" prop, there will be a tad of space. A small piece of electrical tape wrapped around the shaft will work nice to take up that space. I have a boat with a 3mm shaft and dont use any spacer. 3mm is about .118" or so, its very close to 1/8" octura props.
    Steven Vaccaro
    • Dr. Jet
      • 1707
      I am planning on building one of these. I will use Joe Solonger's micro rudder and turn fin with a Fuller's 1/8" strut, Octura 1/8" x 1/16" propshaft and a 1/16" wire drive. Power will be an 1107/1.5Y/H motor on 2S.
      A nation of sheep breeds a government of wolves
      • Mikey P.
        • Sep 2008
        • 48
        Where do I get that hardware. I really don't want any slop.
        I just found this Atomos hull http://www.team-lindenau.de/
        Might do it instead. Will still need similar hardware though
        • Mikey P.
          • Sep 2008
          • 48
          BTW I'm going to use 6s with supervee 27 esc and motor
          • Dr. Jet
            • 1707
            In the 17" DF Micro Hydro? I am not certain it will all fit in there.
            • Mikey P.
              • Sep 2008
              • 48
              dunno, that's the plan though.
              • Steven Vaccaro
                Administrator
                • 8724
                We must be thinking of different boats. All that will sink a mini delta hydro.
                Steven Vaccaro
                • tth
                  • Apr 2008
                  • 1510
                  Not only will it not fit 6s on the esc will let the magic smoke out. Mikey you should reconsider your power options on this hull. 2s would be more along the right size 3s would be a handful of nerves to say the least. Good luck
                  • Ctonez
                    • Jul 2007
                    • 404
                    I did 6s on the SV system by accident once. blew the ESC as well as the motor
                    Went like a bat-outta-hell for about 15 feet though!
                    • Mikey P.
                      • Sep 2008
                      • 48
                      Holy Krap guys!!!
                      Dunno, I'm new to boats. I had a "friend" who was gonna buy one with me. He's been into boats for a while. I've decided he's not much of a....well, he's an A.H. So I'm over building one. Just ordered a Mini cat racing 'Mini Hydro' model.
                      Thanks for the replys!
                      • Rumdog
                        • 6453
                        i run my DF mini vortex with Feigao 380 8L on 3s 2200mah lipo. Mini cat racing micro hydro hardware.32mm stainless prop. Seaking 60 amp esc. gps at 39.8 mph! i custom made a stainless curved turn fin, and it rips righty's like a dream!
                        • longballlumber
                          • 3119
                          That sounds like a sweet setup!!!! got any pictures?
                          • Rumdog
                            • 6453
                            Yeah, i'll try to get some posted tonight.
                            • Rumdog
                              • 6453
                              Her we go, finally. a few shots of my mini vortex. She's a real blast to run. this hull handles awesome for it's size!
