How to apply a Mono Jeff Cheetah windshield decal??
  • monojeff
    • Nov 2010
    • 2728
    Give it a kiss of heat then go over it with your fingernail.
    Then heat it up really hot let it cool slightly and press down on everything one more time.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • monojeff
      • Nov 2010
      • 2728
      They are so small heat may not even be needed.
      Fingernail might do it without heat provided it doesn't start to actually fold.
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
        Thanks John & Jeff
        I'll play with a bit of heat. At first it laid down well but in morning it was up. It's minimal.
        Might redo one side first.
        • monojeff
          • Nov 2010
          • 2728
          Yes this can happen because it was stretched in these areas the most.
          Next time heat set it after you apply it the first time and should hold the corners/stretched areas down.
          The heat if it gets hot enough changes the memory of the adhesive and vinyl.
          Also in response to what john said.
          The longer it sits on the boat the harder it will be to take it off without stretching it when removing.
          Usually 24-48 hrs or so it will still come off just not as easy as if you'd done it right away.
          You should not need to cut them but this method can be made to work if necessary.
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
            Thx!
