I took my TS3 (equipped with an OS lower unit powered by a reclaimed Traxxas Spartan motor) out for a run today. It was the first run and it was a blast out of the gate! I'm pretty sure this boat can do standing backflips on 4S. :)
My question is, how do you maintain the OS lower unit after a typical day of running? Under the advice of the original TS3 owner, I picked up some 20w motor oil and mixed it 50/50 with some 80w gear oil and I use that mixture inside a steel can to inject 1 or 2 pumps of oil after each use...pretty easy stuff. The problem I discovered upon returning home and trying to clean everything out is that the OS lower unit was full of water. As soon as I removed the line plugging the oil injection hole, water came out for a few seconds and it was almost 100% water. I let it drain out and shot 2 pumps of oil into the lower fitting until I could see it come out near the drive dog...all good right? Then I shot 5 pumps of oil into the fitting just below the motor until I discovered water shooting out of the top of the Spartan motor. I figure the water is coming out because the oil is forcing it out...which means the motor is now full of oil as well. Which leads me to start this thread on OSE and ask for help! What should I be doing differently and how do most people maintain their OS lower units after a days run.20150922_200107.jpg
Do you know anything about the copper liner "update"? Benefits?
. man, that's trick, I wouldn't know what to do. I now realize how many people prefer that radio, but I am new to all this and since my first "hobby grade RTF" is a Blade 200QX, I got a DX6 so I will be there for a while before I move up to the FRSky. At first i thought it was a typo , I only knew FlySly, didn't know this brand, and being from China, I thought to myself "man, us Asians really can't speak between "R" and "L"!
