Gorilla Glue Special
  • kburrows
    • Mar 2008
    • 694
    So i bought this cheap 22"by 9" ABS boat and put a SV system in there, didnt take the time to buy all the misc. stuff i glued everything with gorrilla glue to the boat. Very amature way to do it ,but the gorrila glue is rock solid and is very easy clean from these parts. Anyway there is no motor mount, no servo mount and i dont recommend anyone doing this kind of installation for i just wanted to get it in the water .
    Well the boat is also rock solid and built for bashing, i have had it on the sea rocks a few times on dents no cracks, amazing.
    SV guts esc, motor
    BJ outdrive
    14.4volts
    This thing is a rocket. Only thing is i cant get it to full throttle. it lifts to much and then spins out. It rearly ver flips but if it does it rightturns. So cool.
    Total spent on this boat about $160 with out batteries
    i have video of it running will post soon but anyone could help with the spinout problem. It is def. overpowered but allot of fun.
  • lonewolf
    • Jul 2007
    • 713
    Turn fins....
    • Diegoboy
      • Mar 2007
      • 7444
      I did the same thing to the same boat for my daughter. I just didn't go brushless because she's only 6. I agree with Lonewolf, the turn fins are a MUST!
      Also, my water outlet is where yours goes in, and I use a flex cable instead of the U-Joint
      • j.m.
        • 847
        Trim tabs will also help keep the boat going strong at high speeds.
        And so will a more conventional hardware system that doesn't have as much play.
        • kburrows
          • Mar 2008
          • 694
          diegoboy... did you do the Ose outdrive conversion??? which flex shaft did you use? and how did you gt that drive shaft out? i tried many time and didnt want to break it so iam stuck with the u joint. I think the turn fins my help but are'nt they for turning, the the thing is this boat isntflat at the stern so i tried fins and was the same result. I may get soma and tabs and see what happens, thx guys
          • j.m.
            • 847
            The fins are primarily for turning, but they are still in the water helping the boat go straight when you aren't turning.
            If it's going all over the place, then try to use some "regular" cells to keep it in place.
            • egneg
              • 4759
              Once a set screw has been used the shaft may need to be carefully filed or sanded on the diameter to get it past the bearings/bushings which ever may be the case. You will know this if it moves easily until a certain point and then binds.
              IMPBA 20481S D-12
              • Diegoboy
                • Mar 2007
                • 7444
                I used the Octura .130 flex cable. I bore out the outdrive and inserted some brass tube to act as a bushing for the prop shaft.
                j.m. is right, they help keep the back of the boat @ the back of the boat
                Don't be afraid of breaking it, it's just a "basher" baot. You probably won't break it anyway.
                • Diegoboy
                  • Mar 2007
                  • 7444
                  What prop are you running?
                  • kburrows
                    • Mar 2008
                    • 694
                    really dont know i think its an octura dont know the size
                    • Diegoboy
                      • Mar 2007
                      • 7444
                      just wondering if it's a "lifting" prop
                      • kburrows
                        • Mar 2008
                        • 694
                        Hey that might be the case, any suggestions on a good stable prop?
                        • NorthernBoater
                          • 869
                          I have some alluminum trim tabs with turn fins as part of them that would work. I can post pictures tonight if you are interested.
                          • kburrows
                            • Mar 2008
                            • 694
                            sure, how much. pics would be good. thx
                            • kburrows
                              • Mar 2008
                              • 694
                              A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                              Ok here is a short vid, am standing in it but you can see the boats reaction to full throttle. Its kinda rough out there but its allot of fun because the boat is indestructible.
