I'm not sure if I am an idiot, or just plain stupid. All I'm wanting to know is what lipo batteries will work the best for this setup. I've searched the forums and there are quite a few opinions out there, but it is hard to understand acronyms. All I see is 2S2P, 3SP etc. etc. I'm trying to grasp this, but can't. I think I need a crash course in battery training. AMPS, volts, it's all foreign to me. I just don't understand it.....
Also, I know I'm limited on prop sizes becuase if I go any larger, it will rub the transom. If I backed off a larger prop, and the tip is sticking up higher than the bottom, will that cause an issue?
Here are the specs on the motor and ESC.
A3630-1500 Brushless Motor
Specs
Type: Brushless
Voltage: 10-21
RPM/Volt (Kv): 1500
Continuous Current: 45
Speed Control: PRB3309
Overall Diameter: 36mm
Shaft Diameter: 5mm
Shaft Length: 18mm
Overall Length: 74mm
45-Amp Brushless ESC
Specs
Forward: Yes
Brake: Yes
Continuous Maximum Current: 45A
Input Voltage: Minimum 10V, Maximum 21V
Momentary Peak Current: 55A
BEC Voltage: 5.8V
Sorry for the soapbox post, but I'm frustrated...All I want to do is finish this thing and get it in the water. I was pleased with the performance and speed of my blackjack, hence the reason why I am using this setup. I will be happy if they perform the same.
Thanks
Mike
Here's a few pics to show my progress.
Specs
Type: Brushless
Voltage: 10-21
RPM/Volt (Kv): 1500
Shaft Diameter: 5mm
Shaft Length: 18mm
Specs
Forward: Yes
Brake: Yes
BEC Voltage: 5.8V
Thanks
Mike
??? Wow, I just dont get it sometimes. Or maybe I dont get it at all.
