Anyone here work with CAD?
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Hi,
    I'm Glad it fits! not sure about the difference between the DXF and the PDF? it should be the same file. Can you show me a screen shot of how the DXF file came out? when I open the DXF it looks to be the same as the PDF. Can you by any chance import the PDF into what ever CAD software your using? In many cases it will let you import at 1:1 ratio and since the PDF is vector based it should recognize the curve layout.
    • jj2003
      HIGH VOLTAGE ADDICT!
      • May 2011
      • 1710
      OK,
      I downloaded the trial of Autocad 2016 and opened the dxf file in it. It shows up correctly with the curve. It must have been the third party software from google that showed it incorrectly. I have just a few more questions for you but Ill ask after I take the tutorial. Thanks a ton Kent! Your work is greatly appreciated!
      "If guns cause crime, all of mine are defective"
      45"Speedfreek
      , Fightercat #068 ​, MyYoutube Vids
